Jonathan Lerner
How good is the wm1a at driving full sized cans through balanced
The 1z..is it stronger in power in this aspect?It will drive most but not all at least quite well and many very well
i am sold. now if i could only find somewhere in the house 2000$......
It is me, but it wasn't a "Tazzy" it is a pair of Z1R's with nice cable bundles , a 3.5mm TRRS terminated cable, the normal 3.5mm stereo mini and a 4.4mm to XLR (which I inted to use on my friends Fischer audio stack analougue BALANCED IN), I already have a 4.4mm Z1R cable from long a goWell that’s the thing..........the imagination is always bigger than the billfold. Someone found a used one once for $1500 around here.
TA-ZH1ES can definitely be found by $1,500 or so...usedWell that’s the thing..........the imagination is always bigger than the billfold. Someone found a used one once for $1500 around here.
I think when you talk about Android, Google, Amazon Echo, Facebook and then Apple you will find that Apple has the best non tracking non spying record of the entire bunch
Hi guys. I wanted to explore more potentials of my 1a. So I was thinking to use it as pure dac/amp sourced from my iPhone. Is this kind of setup legit? I guess iPhones only have audio out, so 1a could only act as an amp in this case, am I right?
