NaiveSound
- Nov 8, 2015
Sometimes when I press the volume up or down on my 1z I hear clicks, but not each time
Yes, I have a few pm meHello
I'm disturbed : I need to connect my WM1Z to a heaphone amp (Fostex HPV1, with 3,5mm analog audio input), what do I need :
- a special cable like this one https://www.ebay.com/itm/Line-Out-L...-WM-Prot-To-Headphone-Amplifier-/282640398090https://www.ebay.com/itm/Line-Out-L...-WM-Prot-To-Headphone-Amplifier-/282640398090
- a 3.5 / 3.5 audio cable ?
Thank you for your advice
The Fostex manual only says "3.5mm audio input", so I presume I can't use the 4.4 mm balanced output (supposing I would find a 4.4mm to 3.5mm male-male LOD) ?No line out on the WM1Z. You will need a 1/8" mini (male) to 1/8" mini (male) to your amp. If your amp accepts balanced then you will need TRRRS (Pentaconn) male to dual 3-pin XLRs.
No line out but will work with wm port to 3.5mm like the picture from the link, so no need for 3.5 to 3.5No line out on the WM1Z. You will need a 1/8" mini (male) to 1/8" mini (male) to your amp. If your amp accepts balanced then you will need TRRRS (Pentaconn) male to dual 3-pin XLRs.
With the WM port no need to turn the volume as once the wm port is in your Dap volume is disabled, can only turn the volume up or down on the ampYou will need to use the headphone output in single-end and set the volume to max. mini to mini will do the trick.
WM port for sureSo there are 2 possibilities ?
What would give me the best sound quality : connection with a WM dongle to 3.5 amp input, or headphone 3.5 output to 3.5 amp input ?
If you are sure of this, then it's a no go : the amp needs an analog audio input...The wm port will only do digital out not analog
