tgrosu
- Dec 21, 2015
To be honest, I also have a dead pixel on the screen, although the unit is 2 weeks old. Does it have anything to do to where the unit is produced? Mine is from Malaysia.
Is it a pixel black (dead pixel) or stuck in a bright colour (bright pixel)? I don't think it has anything to do with where it is made. Perhaps they didn't specify for a '100% binned' screen for a product that is intended to 'only' sound excellent? That would be additional costs to a feature that doesn't help the product at all. I'm guessing of course (based on my experience as a product manager). But then it doesn't make sense because my NW-A25 have a perfect screen. Again the screen is low resolution and the yield would have been great anyway. It would annoy me though if Sony did this to keep their margin higher on a luxury product.To be honest, I also have a dead pixel on the screen, although the unit is 2 weeks old. Does it have anything to do to where the unit is produced? Mine is from Malaysia.
So true. Its the perspective and usage scenario I guess.Funny I never look at the screen that close as my ears are having an orgasm.
Sadly there is no line level out. I have the Dock which is for adding the DAPs to a computer or Sony TA headphone amplifier and as an added bonus you can use the Dock to go USB to your outboard DAC......then to an amp. With the dongle you can add the DAPs as file players to an outboard DAC then to an amp or just to a computer; also to the TA amp.
It has been said in this thread that using the Dock has added processing which goes above the Dongle to improve the digital transfer either to your outboard DAC or to the TA headphone amp. I’m not sure if it improves connections between the DAPs and a computer?
But going 3.5mm miniplug to 2X RCA to another headphone amp (Asgard One) was not sounding right due to double amping. Though I do go mini 3.5mm to mini 3.5mm to the input at the front of my A/V receiver, just to play a song or two. It sounds OK, but your still double amping.
Your DAC in most cases is going to have a line level out. Many DAPs do have line level outs, but the Sony does not. In most cases we are always attempting to avoid two volume controls, thus double amping. Double amping almost always degrades the signal.
From what I have read your best getting the Dock and going digital USB out using a Audioquest Carbon or Audioquest Cinnamon upgrade USB cable to an outboard DAC then to your amp. I primarily use the Sony TA amp for headphones but could also go 1Z or 1A to the Sony TA headphone amp then go line out with the regular RCA cables to an amp. The TA headphone amp lets you choose between line level out or even volume controlled out, say if you wanted to go RCA to powered speakers and use the TA as your preamp. The expense in this situation is you have to purchase the TA headphone amp. But the upgrade is you get to use the next level upscaling the TA amp uses and past that upscaling along to your speaker amp.
Hi Redcarmoose. Thanks for your detailed response
It sounded to be a real convulted way to enjoy music. If I understand you correctly, or WM1-A will become Transport only connected to external DAC. I am thinking outlouf that I am better off get the TA-ZH1ES or something similar
I will start saving and wait for a while. I am seeing more product like Cambridge Audio.
Thanks
Thanks
Well, it not convoluted when your using it as it’s all basicly options. It’s simple when you use it. But the TA amp is nice as again it offers all the options. Any headphone connection it has. Though it’s not the most powerful amp. I heard it wasn’t the most powerful before I purchased it. But it has all the power I need. It can’t drive the k701s well, but that’s kind of normal, almost nothing can.
But for me going analogue out via the 3.5mm single ended sounded like crap with my Asgard. It was the perfect example of double amping.
Thanks. Seems.i will.go.with standard route. Will do research.
By standard I meant i get sony hap-z1es and connect to Marantz AVR and call it a day or get integrated DAC & amp connect to Marantz eith HT bypass. I am just getting back to music. I am not in rush and don’t really have luxury to sit and listen without disturbing others. For now i will just sit and learn here ane be happy with Wm1a and headphones. Have been looking at Gustard product too. Exciting it is.Laughably.............I quoted you the standard route? There is no other choice. It may have seemed confusing but your going to have to get to a DAC and bypass the Sony amplifier stage. There is simply no other way, unless your into bad audio.
It only seems convoluted when your on the learning curve, but once you own a dongle or have the Dock, this stuff is pretty simple stuff.
The cheap route is get the dongle and get a low cost USB DAC, you’ll notice the difference from using a 3.5mm cable to RCA to an amp.
Good luck.
I would rather not making too much compromises because I will end up spending more upgrading.
are you by chance in Singapore?You tell me about it! Lol! Anyways, if you are happy with portable and the way that it is, don’t bother the little things, otherwise you will be spending your next car on a system LOL
