SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
meomap
Coffee was nice but that place had lots of mosquitoes
Hi,
Why there are two Z1 there?
meomap
Hi,
Need some help with sd card with MBP format.
Received a new SanDisk 256 gb.
Formated card using exFAT.
Transferred some music from ITunes.
Loaded into Z1. Saw unit reading and create database sequence, but at the end SDCARD still show as 0.
What should I do next?
P.S. Connected Z1 to MBP and transferred ITunes Music OK.
Did you create "Music" folder on the card? WM series assumes that all the music files are in the "Music" folder.Hi,
meomap
Hi,
I did not. Let me create Music folder and see.
Thank you very much.
meomap
I noticed when I copied and paste albums from iTunes/Music to my Sd Card, it created a MUSIC folder. I did not know where/what/how is that folder got created, so I ignored.
Once you mentioned it then I looked again inside the 256 GB card and there it is.
Moved all albums to MUSIC.
Put card into Z1, read, and voila.
Thanks a lot @Giraku.
gerelmx1986
Hope Sony can make a software fix so they get rid of that music folder and just read music files from whatever folder they are stored. That would provide an easier migration from player x to Walkmans
Ryokan
It doesn't bother me too much, but is a little odd/quaint. It was the same for a Sony player I had over 10 years ago. I wonder what their reason is.
Fully agreed.Hope Sony can make a software fix so they get rid of that music folder and just read music files from whatever folder they are stored. That would provide an easier migration from player x to Walkmans
I guess the software engineers at Sony like that way of organizing files.It doesn't bother me too much, but is a little odd/quaint. It was the same for a Sony player I had over 10 years ago. I wonder what their reason is.
They always like their "own" way.
blazinblazin
- Nov 19, 2015
It's SONY way of organising files in their SONY ecosystem.
It would be nice if you could also play an all songs shuffle within each of those folders as an option. You could actually create your own genre folders. Wishful thinking.Hope Sony can make a software fix so they get rid of that music folder and just read music files from whatever folder they are stored. That would provide an easier migration from player x to Walkmans
- Jul 16, 2016
thanks. I did the adjustmentYou should check your Bluetooth configuration on the wm1. There are options which are designed to improve connection robustness.
tienbasse
- Dec 5, 2011
Agreed 100x times.Hope Sony can make a software fix so they get rid of that music folder and just read music files from whatever folder they are stored. That would provide an easier migration from player x to Walkmans
This is such a pain in the b*tt, it makes demo-ing these DAPs a horrendous experience, because you usually come with your own microsd cards and end-up not being able to use them... Sony's obsession not to do things following standards...
- Jul 16, 2016
What is the best way to recharge the battery? Simply plugging it into a pc anc charging it that way? Is the iphone ac adapter a good way to recharge it? I used the search function and have not found any thing.
thanks
thanks
- Status
Total: 20 (members: 1, guests: 19)
