SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Mar 23, 2018 at 2:18 PM Post #19,201 of 45,723
What is the best way to recharge the battery? Simply plugging it into a pc anc charging it that way? Is the iphone ac adapter a good way to recharge it? I used the search function and have not found any thing.
thanks
Both ways are fine
Mar 23, 2018 at 3:30 PM Post #19,203 of 45,723
thanks
I've never used my laptop usb because it quits charging if the laptop goes to sleep. I've only used my iPhone wall wart and it's worked fine, no problems.
Mar 23, 2018 at 5:26 PM Post #19,205 of 45,723
Sony is making it easy for the system to ‘fast read’ the files by placing it in a folder.
Do you want it to scan non music files too every time without this folder?
Jeez talk about whining
How many music files do you have on your card? I don't have many. Also reading through files happens when you correct it to computers, which is not often. I prefer having better compatibility to sticking to a not-widely-used method.
Mar 23, 2018 at 8:13 PM Post #19,209 of 45,723
Usually a 8 wire cable opens up the soundstage, for vocals and instrument, I think the best is the eros, but it also depends which earphones do you have.
Im getting for my HS1551CU. May i know which cable fo u suggest?
Mar 23, 2018 at 8:25 PM Post #19,210 of 45,723
How about eres2?
Mar 24, 2018 at 12:16 AM Post #19,212 of 45,723
thanks
I have found a 1.1 amp charger would not charge the unit, and so I am using a 1.3 amp charger in a wall plug because the lower amps gives a deeper charge. I prefer not to leave it connected to a pc and only have it connected when syncing.
Mar 24, 2018 at 12:28 AM Post #19,214 of 45,723
got this one, the complete bach organ by hans fagius, its 5 disks but each is 10gb because its super extended play sacd, total playtime is 20 hours! 50gb for 20 hours lol.
i heard of that one but i am doubtful if it is really DSD or just 44,1KHz jampacked into a DVD-sized disk (4,7GB)... I read originally BIS released this in the late 80's early 90's as CD, recorded in 44.1KHz/16bit.... My 21 CDs or bach organ works with hanssler and naxos and a sony classical remaster in SACD (from tapes) gives me 20+ hours. My 5 SACD set from ALIA vox Marais pieces de violes is 10,4GB
Status
