Mine has never done this. Possibly if you are using Music Center to transfer, you could try transferring directly from Windows explorer, or vice versa if you are currently using Windows explorer. Just a thought, and also assuming you are using windows and not a Mac.I am having a tiny issue. I have unplugged my WM1A from the computer after loading new music on it, and I check out my recently added section only to see my entire library listed instead of my newest additions. It has done this the last 2-3 times I have added music and I am not sure why the recently added isn't working properly.
Any suggestions?
SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
- Oct 14, 2013
Well, I stick with my Clear TPU case
nc8000
Yes that is what I have also ended up with as the player fits in the dock with it on as opposed to the otherwise lovely Dignis Walkman case
aisalen
- Mar 17, 2017
I also like the TPU gel case more than my sony original case, which for me is bulky. This is only way to protect and at the same time to show off the player.
superuser1
Is that a yamazaki or a hibiki?
here it all is
bana
- May 21, 2014
Sorry to say but it looks like a block of black sponge, I agree the back looks nice but considering the cost of dignis in general ( plus I also have import and Vat duties as well to pay ) it's not a good look not to mention the fluff this is going to attract, I'd use their returns policy and treat yourself to one that goes nicely with your slab of gold goodness.
I got one as well, classy, but I'm think of going back to my clear case.
buduba0604
I will try downloading music center and see if that fixes the problem. It's worked for the past six months, but just decided to stop the past few times.
EDIT: Nope, it didn't work. I am quite puzzled.
gerelmx1986
As I like mefia go i decided to keep the installer
Me too. I like it much better than Music Center!As I like mefia go i decided to keep the installer
buduba0604
So I manually rebuilt the database from the settings menu, plugged my WM1A into the computer and added an album. Unplugged it from the computer and it looks like it works! Shows only the single album I added to my WM1A in the recently added section.
I am happy now! Woo!
Hibiki.
480126
- Jul 20, 2017
I think the best looking and cheapest case come from valentinum, Polen (etsy.com)Sorry to say but it looks like a block of black sponge, I agree the back looks nice but considering the cost of dignis in general ( plus I also have import and Vat duties as well to pay ) it's not a good look not to mention the fluff this is going to attract, I'd use their returns policy and treat yourself to one that goes nicely with your slab of gold goodness.
Now I really need to look into the return policy from Dignis ...I think the best looking and cheapest case come from valentinum, Polen (etsy.com)
- Status
