SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Dec 29, 2017 at 3:22 PM Post #17,686 of 45,723
Dec 29, 2017 at 3:23 PM Post #17,687 of 45,723
If you're crap at putting a screen protector on, doesn't matter which one you get, they are all the same to install Find which ever one you can get hold off and have someone to do it for you, the best is probably the Benks or gamas brand, you can find those on ebay, aliexpress or amazon.
I never was able to find the Benks one. Is it specifically for the Sony? I think I'm okay at putting the protectors on I just got that one effing piece of dust on there that screwed it all up...
Dec 29, 2017 at 3:51 PM Post #17,689 of 45,723
Wipe it down with alcohol wipes first then spray it with an air can to get all the dust out of the way.
How important is a screen protector if you always have the thing inside an airtight case or a soft velvety pocket with no other stuff in it?
Dec 29, 2017 at 5:18 PM Post #17,692 of 45,723
put a screen protector guys , it costs nothing and saves you from all the stress
this is a no-brainer.
Dec 29, 2017 at 5:24 PM Post #17,693 of 45,723
I’d say do it but it’s really up to you. If you clean it down first like I mentioned it should be fine.
That said I don’t handle my Walkman the same as I do my smartphone and I don’t have a screen on my smartphone..... so don’t listen to me I don’t know what I’m doing any more. :)
Dec 29, 2017 at 5:37 PM Post #17,694 of 45,723
Mine is naked screen and up to now, not a single scratch, just don't put any coins or keys on the same pocket
I'm going to try the 9N glass protector for the Sony...
Dec 29, 2017 at 5:43 PM Post #17,695 of 45,723
Dec 29, 2017 at 5:44 PM Post #17,696 of 45,723
Dec 29, 2017 at 9:04 PM Post #17,698 of 45,723
I will be checing the dropbox or other hoster, trying w/google drive
  • sacdISOs2EMflac.zip
Dec 29, 2017 at 9:09 PM Post #17,699 of 45,723
Dec 29, 2017 at 9:47 PM Post #17,700 of 45,723
Status
