NaiveSound
- Nov 8, 2015
Anyone else able to mention bout ph3 vs wm1a
Woa, you would go as far to add additional Capacitors ? In parrallel or what ? I wouldn’t touch anything on the hard-components beside the wires. Because doing so, will essentially transform the Wm1Z into something else, and no longer Sony signature move anymore. Wires upgrade ? Now there are a whole lot of reason to do it. If I would swap out any hard-components, I would rather sell the 1Z and buy something else
Not to criticize anyone, but let me ask. How does a copper foil provide shielding to “any chips” without “proper grounding” ? You do know that Metal, and or Metal foil, without proper grounding, instead of acting as a shield, can act as an antenna ? The best way to provide additional shielding is to Copper foil on the back of the black plastic casing and connect the foil to the main chassis, but leave the space for Bluetooth antenna to send signal through. However, doing this will decrease the Bluetooth antenna range. Ultimate way to do this would be to completely take out Bluetooth antenna, and NFC antenna. Then custom mill a CNC Copper-Gold Plated back plating, then screw it on.
I am selling my Lotoo Paw Gold after a month of living with both.
LPG's advantage over WM1Z: fast UI, fast power on/off, fast file transfer. I need confirmation from somebody that WM1Z will work with the 400GB micro SD card!
WM1Z's advantage over LPG: One complaint I have with the LPG is that treble from the headphone jack is way too bright. Still I would recommend LPG over WM1Z if one is using JH, Shure, Westone, etc. the usual TOTL dark-sounding stage monitors, but to pair with my collection of headphones, I'd prefer something more neutral. Line out from LPG doesn't have that problem though. The tuning of WM1Z on the other hand is amazing. Very neutral and balanced, yet full of emotion and body. As a plus, WM1Z's soundstage is wider and deeper than that of LPG.
Selling my Sony WM1Z, as I am getting into full-size headphones.
https://www.head-fi.org/threads/fs-sony-wm1z.863850/
What full size headphone specifically are you after ? 1Z works fine with many full size phones.
Hi Edric Li.I am selling my Lotoo Paw Gold after a month of living with both.
You might want to try the new Sennheiser HD660S. It has upgraded drivers and comes with a 4.4 mm Pentagon balanced cable. Have it since some time now and must say it pairs wonderful with the WM1A.I want the NW-WM1Z! I think I will be happy with my Shure SRH1540 and Audioquest Nighthawks in balanced. Surf cables. I love the NW-WM1A, but...the itch begins!
You know that the WM1Z has a parametric EQ, don't you?I am thinking about the HD800S, because I've had comfort issues with full size headphones before and the 800 is one of the comfortable full-size HPs out there. Also one other reason I am sticking with the LPG over the 1Z is the Parametric EQ on the LPG.
