NaiveSound
- Nov 8, 2015
Thanks NC8000, thats good to hear, I was looking at a 256gb but if that is the case 400Gb is okay then I might just go with one. How much did you get your 400GB one for if you don't mind me asking?
By default in which means, sound, features or overall?...as the ZX300 has some newer features and different UI options present which probably some of that will come in the update for the 1A soon anyway.
If sound then that's in the eye of the beholder and probably best to listen to both if you can. At the end of the day the new model has come out at £400 cheaper than the 1A and to me that is probably on sound alone in the right area but they are two different signatures to me hence why they need a first hand listen so you can decide as only your lug holes will tell you which you prefer and then battle with the ergonmic differences and price differences into the mix and see where your heart takes you ; )
How would you describe wm1z (cheaper version) in sound signature? Forward? Mid centric? Resolution?
