Matrix Petka
Does it need to be a 4.4 mm connector on the cable to the IEM or will a balanced 2.5mm jack through a converter to 4.4 mm work with the 1A?
Cheers
If you have balanced cable with balanced 2,5mm connector, you can use converter 2,5mm female to 4,4mm male.
