I’m sorry if this has been discussed before but can anyone tell me how to disable google voice on NW-WM1ZM2. When using the Sony music app, If I try and search I can only speak. It will not give me a keyboard option.. Also, any other recommendations for a new Sony user? Settings, music player app’s, whatever.. Appreciate any help in advance.
SONY NW-WM1Z M2 / WM1A M2
Have a look at the NW-WM1A/Z M2 debloating thread here.
Where..?Have a look at the NW-WM1A/Z debloating thread here.
https://www.head-fi.org/threads/sony-wm1am2-and-wm1zm2-android-walkman-optimization-guide.962975/
Amber Rain
- Aug 26, 2016
When I updated to FW 1.07 (? the latest one) it essentially stopped me using it as a transport to my DAC/Amp!!!Has anyone heard improvements or drawbacks through the various firmware for wm1am2? I have a zx507 and zx1 before that, I usually notice a difference in sound between firmware with them. I would always stop updating when I really liked a firmware or saw posts about the latest firmware negatively affecting the sound >.<
I finally got around to ordering a wm1am2, I wonder what firmware it will come with
When I try to use any other applications (Onkyo etc, the supposed solution to this issue, rather than using the Sony app), it just crashes every time.
Does anyone know if it is possible to roll back the FW? If so, please let me know
I will try a factory reset if that happen, i remembered the developer options freezing during one of the updates, forgot it was my A306 or ZM2, but it solves the issue.When I updated to FW 1.07 (? the latest one) it essentially stopped me using it as a transport to my DAC/Amp!!!
Amber Rain
- Aug 26, 2016
Thanks, I didn't think of that. I'll try it.I will try a factory reset if that happen, i remembered the developer options freezing during one of the updates, forgot it was my A306 or ZM2, but it solves the issue.
ozz007
- Mar 2, 2012
I used the Sony to connect to my chord Hugo and I don't have any issues .When I updated to FW 1.07 (? the latest one) it essentially stopped me using it as a transport to my DAC/Amp!!!
I used it with tidal no problems. When I plug the USB cable I t asked if I want to allow tidal to used the Hugo I just click anywhere else but the message and it works.
If I click on the yes tidal won't pass the music to chord hugo.
I'm on 107 version also
Amber Rain
- Aug 26, 2016
Oh thanks, I'll try that firstI used the Sony to connect to my chord Hugo and I don't have any issues .
asdfghjk
I have only compared the Swissbit to the 1zm2 Internal storage. But thats a good question, I will order one of the decent brand consumer grade micro sd card and report backWhich non-industrial microSD cards did you use before?
roadrat
- Oct 4, 2012
You're going down a rabbit holeI have only compared the Swissbit to the 1zm2 Internal storage. But thats a good question, I will order one of the decent brand consumer grade micro sd card and report back
Sonywalkmanuser
I am quite intrigued by the new Samsung Pro Ultimate. It is touted to have a more power saving and high performance host controller. Not really that expensive but finding one can be challenging as its very new.I have only compared the Swissbit to the 1zm2 Internal storage. But thats a good question, I will order one of the decent brand consumer grade micro sd card and report back
If I may suggest, try SanDisk Extreme Pro please.I have only compared the Swissbit to the 1zm2 Internal storage. But thats a good question, I will order one of the decent brand consumer grade micro sd card and report back
And where would Alice be if she never went down that rabbit hole?You're going down a rabbit hole
She would have happily lived forever. And she would have been stinking rich.
Total: 33 (members: 13, guests: 20)
