- Mar 22, 2014
I would probably go with a portable amp if you like the LG (which I do). Budget for a DAP in the future when your phone gives up the ghost
You have a very very tight budget but i was looking what would be worth to plug it into the WM1AM2 for that price.I like music from the 80s and generally listen to everything I don't like analytical accurate cold dry headphones, I like slightly colored headphones
If you save up some money, there are a _lot_ of very excellent choices from all over the world. 500€ really is a very very tight budget.I might be tempted to import if it's worth it
Does this "clicking noise" happen when the player switches sample rates (e.g., 44khz to 96khz, PCM to DSD, etc)? It's the sound of the relay like others suggested.thanks for that. i can't reproduce the flickering issue consistently so i do wonder if this is software related.
also of note is the "clicking" noise i'm starting to get from the player now. The type of sound you hear when a hard disk is clicking.
i'm puzzled by this one since there is no disk drive/mechanical sounding parts in the player (at least to my knowledge)
I don't think it will ever be possible. The ZX500 is from 2019 and it doesn't work with that one.Are headphones a good choice campfire audio andromeda I found a used one, are you interested in them? possibly what others can also be used that will go well with this sony
I would like to know one more thing, if you were to buy a player, which version would you choose, or are they enough, which can be modified, I will add that the difference in price compared to the new model is around 100€ or 500€ for the new model, 400€ for the old one Another thing I'm curious about is whether there is a noticeable difference in sound between the models wm1a vs wm1z ?
Do you think there will be a possibility to unlock wm1am2 volume limit in the future
I picked mine up last week for £800 so just save a little, it will be worth itThis Sony is a big block with little power, I think I'll let it go I also have a question for you which other used player to buy I like retro sound warm musical I don't like analytical bright sound what can you advise me ?
The Sony Players do not have an retro warm musical sound. They have Full Digital Amps, so they have an very fast and direct sound. I already wrote you an private message but the amps that sound closest to the S-Master HX, in my experience, are the THX AAA amps. As far as i know, currently only FiiO is using them. The M11 Plus ESS would be the equivalent then.This Sony is a big block with little power, I think I'll let it go I also have a question for you which other used player to buy I like retro sound warm musical I don't like analytical bright sound what can you advise me ?
The amp decides if an device sounds warm, not the DAC.And from my humble experience xaden DAC ESS chip not for a warm and musical sound I would be more inclined to AKM DAC sttone only what equipment to choose with this chip fairly new I'm thinking about buying a used Dap so that it had support for stryming and walked decently
The Fiio M11 Plus is just as much of a "brick" as the Sony A2 (I have both). M11+ more versatile; proper line outs (SE + balanced) as well as SPDIF out, 3 levels of gain. But I still prefer listening to the Sony.The Sony Players do not have an retro warm musical sound. They have Full Digital Amps, so they have an very fast and direct sound. I already wrote you an private message but the amps that sound closest to the S-Master HX, in my experience, are the THX AAA amps. As far as i know, currently only FiiO is using them. The M11 Plus ESS would be the equivalent then.
I guess emphasis is more on the quality of component and sound quality than on power. Which IEM are you using? I feel the unit without volume cap can drive pretty much any IEM to ear shattering level.This Sony is a big block with little power, I think I'll let it go I also have a question for you which other used player to buy I like retro sound warm musical I don't like analytical bright sound what can you advise me ?
