It's a bit yellow from some angles now itself...I hope it goes full yellow (gold) and it converts my 1AM2 to a 1ZM2Yep great case. looks like you went for total clear version. I went smoke/clear version as this material in pure clear version tends to age yellow.
SONY NW-WM1Z M2 / WM1A M2
psikey
- Jul 15, 2008
Yes, will enhance the yellow of a Z1M2It's a bit yellow from some angles now itself...I hope it goes full yellow (gold) and it converts my 1AM2 to a 1ZM2
I gave up a1ZM2 as preferred 1AM2, and not just for the £2K+ saving.
Some are giving up the 1AM2 for the A300 so...Yes, will enhance the yellow of a Z1M2
psikey
- Jul 15, 2008
I'm considering it myself Been using my Japanese A307 for 2 days now and amazing little dap if happy with just 3.5mm and its power level. (listening to it now)
With some tastefully done EQ, I am enjoying the UM Mest Indigo with WM1Z. The sound is bombastic
I haven’t used my desktop rig for past few days.
cFkoauvicGBK7o
Is it possible to describe the sound differences between the A300 and WM1AM2?I'm considering it myself Been using my Japanese A307 for 2 days now and amazing little dap if happy with just 3.5mm and its power level. (listening to it now)
psikey
- Jul 15, 2008
Main thing that jumps out for me is A1M2 sounds warmer, cosier with greater sound stage and super silent background, while the A307 has more bass kick. I'm 56 soon so don't have the high end resolving ability of those with younger ears.Is it possible to describe the sound differences between the A300 and WM1AM2?
I've not done a lot of A-B listening yet. I can say if I didn't have a 1AM2 I'd be perfectly happy with what the A307 puts out with my IEM's except maybe not my Shure SE846 as I do like a black, silent background and slight amp hiss with the sensitive Shure's.
When I had an A105 & ZX507 I preferred the 3.5mm output of that over the 3.5mm output of the ZX507. I suppose with a DAP that only has a 3.5mm port they can focus 100% to optimise its single output to get perfect with the component choice.
I am actually considering sticking with just the A307 as so portable and OS/SOC is snappier and I can live without balanced.
cFkoauvicGBK7o
I was after an AM2 but I'm thinking about the ZX707 now. It's a bit cheaper and seems more portable than the AM2. I don't really like the design though, don't really like the gold bits on the output and the battery life doesn't seem great.Main thing that jumps out for me is A1M2 sounds warmer, cosier with greater sound stage and super silent background, while the A307 has more bass kick. I'm 56 soon so don't have the high end resolving ability of those with younger ears.
But then I think maybe I should get an AM2 and literally never upgrade ever again. And since it's my "last portable audio" purchase I should just go all out.
Probably going to wait for some reviews to come out and make a decision in a few months...
How's the pairing without EQ?With some tastefully done EQ, I am enjoying the UM Mest Indigo with WM1Z. The sound is bombastic
10DeeQ
- Jan 6, 2013
Bought a new iem to try
Sometimes Z1r is sounded too “grand” for casual listening before i sleep
pholcus1975
It's a Senn ie200, isn't it? How does it pair?
The1Signature
It seams to be. It is also written in his signature.It's a Senn ie200, isn't it? How does it pair?
michaelpunym
I have got a pair of IEM to match my WM1ZM2, but if I need to use its Bluetooth functionality, are LDAC supported earphones/headphones the only choices to get the best audio quality from WM1ZM2?
Total: 35 (members: 6, guests: 29)
