Sonywalkmanuser
I won’t recommend using Samsung Gan chargers if you value your Walkman’s battery lifespan. It has too much ripple, most other chargers are under 100mv, typically 40mv and the best ones around 20mv.
![0D9543A2-3706-4801-9FB3-B505290E39E9.png 0D9543A2-3706-4801-9FB3-B505290E39E9.png](https://cdn.head-fi.org/a/11965833.png)
![77C4BF4B-9780-4DC1-B6F2-3EA1DDA2469E.png 77C4BF4B-9780-4DC1-B6F2-3EA1DDA2469E.png](https://cdn.head-fi.org/a/11965832.png)
You will have the Google play store if it’s the Japanese or international version.Mine is a Jap unit. How do I check if it's the international version?
Not exactly sure. I don’t think there’s one charger that can be the best at everything if you factor in cost. Just avoid Samsung.So which charger is the best?
I just tried Direct mode playback and yeah, it run about 30 hours from battery 100% to 20%. Battery looks fine.yeah, that's the main reasons i have been holding on this unit for months, i was thinking maybe aac lower res file needs more DSEE power to upscale, hence increasing the power usage. I will try the Direct mode method on the next full charge.
Btw, DSEE Ultimate really upscales aac files like champ, it was as close as a FLAC file.
I did an update database and hour ago, looks better, 5% per hour now, i will keep monitoring. Will report back the next full charge using Direct mode.
I have 2 of these, and always like the Xiaomi products. Good to know this is a good one to use, with low ripple, if charging and playing music at the same time. Though I use a 65W GaN charger most of the time for fast charging convenience on the Ipad. (and Sony)For ripple performance, I think this is likely top of the pack:
https://lygte-info.dk/review/USBpower Xiaomi Mi 60W Fast+QC+PD usb charger CDQ06ZM UK.html
https://ifi-audio.com/products/ipowerx/ curious about their products. They have a coupleFor ripple performance, I think this is likely top of the pack:
A battery may not always a better option. I had thought the same, that a battery was a good replacement for an AC power source, as I thought of it as similar to using a car battery. Simpler and more direct. Just a battery, with no complications. But this is not the case.I normally use my 20000mah battery pack as a charger proxy.. in effect minimise ls issue with mains to 5v conversion. Or use wall socket USB sockets. Having had my daughters multi usb mains charger go wrong, l and taken it apart they aren't built very well at all.
