MrWalkman
Do I read correctly M2 converts all PCM files to DSD?
Not by default, but this is available as an option.
WM1ZM2 | SP2000 | |
Height | 142.5 mm | 132 mm |
Width | 80.5 mm | 76.3 mm |
Depth | 21 mm | 15.7 mm |
Weight | 490 g | Steel : 410.8 g - Copper : 432.4 g |
The AK SP2K cannot do PCM to DSDComparing WM1ZmkII with A&K SP2000 size and weight
WM1ZM2 SP2000Height 142.5 mm 132 mmWidth 80.5 mm 76.3 mmDepth 21 mm 15.7 mmWeight 490 g
Using "Maximum External Dimensions" for WM1ZM2.
"External dimensions" are 141.4 mm / 75.6 mm / 20.8 mm
1. I was only comparing size and weight of these 2 TOTL DAPSBut A&K software and hardware are usually almost obsolete evey time.. and A&K developers are almost never able to fix issues of their software.
I would never imagine comparing Sony and A&K ..
SP2000 vs WM1am2 is going to be like Hulk vs Thanos dude.1. I was only comparing size and weight of these 2 TOTL DAPS
2. I know that you had a very negative experience with an A&K (Kann Alpha) but this is not my case, I own a SP2000 and it's working perfectly, I don't have a single bug, firmware is regularly updated
I think a big part of it is Sony is in the smartphone business. Xperia 5 iii would easily last 50+ hours just playing audio. They can surely take the same battery technology and sources and just adapt it for the walkman.
While other DAP makers just don't have the pedigree. Astell & Kern is tiny compared to Sony, they dont have an entire smartphone arm to draw expertise from on battery efficiency etc. Hence AK make DAPs with 8 hour battery life in 2022, while Sony made DAPs with 20+ hour battery life in 2016. Even chord can't squeeze more than 10 hours on their portables....Sony really stands out in this regard and are poised to take the DAP market almost entirely from AK this generation imo.
No, you have mistaken it. That is the FETs that are used for amplifications and not the S-Master@nanaholic you say sony has no new S-Master chip yet. What about the new S-Master chip inside SA-Z1? Made with GaN-FET instead of MOSFET
And why walkman dont use such FETs for amping instead the induxtor coils and capacitors?No, you have mistaken it. That is the FETs that are used for amplifications and not the S-Master
