This stereo cassette player edition commemorates the former Walkman (TPL-2?) released in 1979. The case thus resembles the cassette player design. That is why there is only one colour in this edition.Only one color?
SONY NW-WM1Z M2 / WM1A M2
psikey
- Jul 15, 2008
Thought about the IER-M9? Sounds great and super comfy, though 5BA.has anyone compared Sennheiser IE900 to the Sony IER-Z1R? I really liked the IER-Z1R but the fit is not ideal for me for long listen sessions.
I recommend also looking at offers for IEMs with custom fit. I had the opportunity to test a model available with standard and custom fit. Besides the really good fit reaching your ear canal the overall audio quality I experienced was noticeably superior with the custom fit. I tried different rubber plug sizes with the standard fit but in the end I easily went for the custom fit. For sure, it's not simply try-and-buy but I think the effort is definitely worth itI had both. They are different but for me the comfort of IE900 can not be matched. Soundwise both are high end pairs of IEMs worth the investment.
The1Signature
one has to mention that ie ie900 goes very deep into the ear. and if it fits right, you will hear an amazing bass.I had both. They are different but for me the comfort of IE900 can not be matched. Soundwise both are high end pairs of IEMs worth the investment.
the ie900 is so flat one can almost sleep with it, laying the ears on the pillow without getting disturbed.
psikey
- Jul 15, 2008
I can do that with my Fiio FD7's. Personal I think thats an excellent single dynamic driver IEM.one has to mention that ie ie900 goes very deep into the ear. and if it fits right, you will hear an amazing bass.
I completely agree. I had custom qdc anole and Layla aion made and they are so far superior to anything else I have experienced I can’t describe it. I firmly believe a custom mediocre iem will outperform a flagship standard iem any day, particularly if you have unusual ear sizes!I recommend also looking at offers for IEMs with custom fit. I had the opportunity to test a model available with standard and custom fit. Besides the really good fit reaching your ear canal the overall audio quality I experienced was noticeably superior with the custom fit. I tried different rubber plug sizes with the standard fit but in the end I easily went for the custom fit. For sure, it's not simply try-and-buy but I think the effort is definitely worth it
chortya
- Feb 14, 2017
My challenge with customs is that they really need to fit well. I currently have some discomfort witt a pair of Fibae 7u, probably will need to get them refitted.I completely agree. I had custom qdc anole and Layla aion made and they are so far superior to anything else I have experienced I can’t describe it. I firmly believe a custom mediocre iem will outperform a flagship standard iem any day, particularly if you have unusual ear sizes!
Also you cannot easely resell them.
Indeed, you have to look for the process. Re-fitting is possible with most of the manufacturers or dealers, within limits.My challenge with customs is that they really need to fit well. I currently have some discomfort witt a pair of Fibae 7u, probably will need to get them refitted.
Reselling is more or less impossible. Sometimes, manufacturers offer special price for new purchase when sending in used device.
Superpong
- Aug 2, 2007
Anyone experiences this problem?
I migrate the MicroSD card that I used with AK. Songs and playlists in the card can be played and showed normally. However I cannot add a new song in the existing playlists. Once I try, the playlist name is greyed out.
However, I can add songs in the playlists created by the player.
Your card needs to have a MUSIC folder. Put all your music in there, otherwise Walkman won't see it.Anyone experiences this problem?
Superpong
- Aug 2, 2007
Yes..I do. I put all album folders and playlist in the Music folder.Your card needs to have a MUSIC folder. Put all your music in there, otherwise Walkman won't see it.
sanakimpro
- Nov 27, 2014
YMMV but I debated this for a few months and went with the Z1Rhas anyone compared Sennheiser IE900 to the Sony IER-Z1R? I really liked the IER-Z1R but the fit is not ideal for me for long listen sessions.
> For me, the bass quality, soundstage presentation and layering of the Z1R is just top-tier with the right source
> Z1R fit and weight is not an issue for me despite initially being a huge concern
> I always achieve a great seal unlike with the stock tips on IE900. I recalled at different demos that I had wildly different impressions depending on the eartip size, depth of insertion etc
> I love the Z1R look and the cables as well - they look more premium and softer than the IE900
You can always search on IE900 and Z1R threads for more as this has been discussed a lot.
IE900 is really excellent. If Z1R fit is an issue, I'd recommend IE900 as an alternative. No, it's not as good as Z1R sonically, but it gets close enough with much better comfort for some. For the same money, if you don't mind getting customs, CFA Supermoon is significantly better than IE900 and very complementary to Z1R if you already own one.has anyone compared Sennheiser IE900 to the Sony IER-Z1R? I really liked the IER-Z1R but the fit is not ideal for me for long listen sessions.
I'm having the same issue, did you solve it?My M2 definitely has issues returning from black screen. Sometimes pressing the power button simply doesn't bring the screen back. Sometimes it takes three tries. And sure, sometimes screen comes back at first press.
Device hasn't turned off by it self. Only screensaver.
pholcus1975
I would try a factory reset.
Total: 27 (members: 7, guests: 20)
