SONY NW-WM1Z M2 / WM1A M2
Feb 12, 2022 at 10:50 AM Post #271 of 15,987
What a collection! I should still have a box full of LPs in my store room but I no longer own a player. Most of my music are CDs but I'm slowly moving to digital to save space in the house.
Do you still listen the LPs on player directly sometimes?
I’ve got the Rega P25 (their 25 year jubilee model from about 20 years ago) for lp’s and the Rega P78 specifically for the old 78 rpm records
Feb 12, 2022 at 12:23 PM Post #273 of 15,987
Feb 12, 2022 at 12:24 PM Post #274 of 15,987
Feb 12, 2022 at 1:51 PM Post #275 of 15,987
I bought a Rega P8 and Parasound JC3+ last year for listening and ripping vinyl.
Feb 12, 2022 at 3:58 PM Post #276 of 15,987
It is a lot of work but if you run a Vinyl recording through spectralayers it is possible to greatly dampen the pops and cracks from the format while maintaining the dynamics and warmth of the medium.
Feb 12, 2022 at 4:04 PM Post #277 of 15,987
For people with the TA-ZH1ES and wonder how to connect the new NW-WM1AM2 and NW-WM1ZM2 it's fairly simple, a USB-C to micro cable will do the trick, I tested just now it worked perfectly
I could be wrong about the functionality, but I think the TA-ZH1ES is supposed to charge the NW-WM1A by using a special micro cable with an extra pin to the side of the micro connection.
Feb 12, 2022 at 4:17 PM Post #278 of 15,987
Yes it does with that cable.
Hopefully Sony will release a USB-C to Walkman port cable to support the MK2.
Feb 12, 2022 at 4:20 PM Post #279 of 15,987
Yes if it also have to charge the connected device a special cable would be required, for just dac functionality a usb-c to micro usb will do
Feb 12, 2022 at 5:26 PM Post #281 of 15,987
Can someone who visited Sony store, please show pictures of Both 1Z and 1A boards side by side please
They are the same this time, no different caps or resistors - only different interconnecting wire and enclosure material.
Feb 12, 2022 at 5:55 PM Post #283 of 15,987
Plus the extra 128GB storage
Feb 12, 2022 at 6:16 PM Post #285 of 15,987
I'm not familiar with Android DAP so my expectation can be really low compared to others. I think if I buy this I can be happy with it. It feels smooth enough as a music player. Creating database also faster but I didn't copy too many files. Switching between apps (Chrome/Walkman/Apple Music/Spotify) is quick enough. It is only a tad smoother than the ZX507 next to it so I don't know how it will hold up with huge music DB.
I tried USB DAC mode + MDR-Z1R to my Samsung Note 10+ and it works just nice. Driving power wise there is a tiny difference of 2-3 steps but I didn't A/B them. I think I can safely say that they are about the same.
Much appreciated!
