MrWalkman
Just wondering how good is the ripping capabilities.https://www.sony.jp/walkman/store/special/cdreco/
Unless it processes the sound in some way, the CD data is digital, so I don't see what could be better.
I'm rather skeptical here. Not regarding some sort of ripping quality but when it comes to usability. We know any internet source for getting the right/wanted music tags has loads of errors or unwanted notations. I guess in case the tagging is important to you manual editing won't be fun with such a device, if possible at all.Unless it processes the sound in some way, the CD data is digital, so I don't see what could be better.
Ah, o.k. It sayshttps://www.iodata.jp/ssp/cdreco/cdreco/
It seems that it's usable with any Android device, and even with iOS ones, and you can also burn audio CDs.
Seen the video previously from Hans Beekhuyzen, he did mentioned something about older or less processing power PC is better for ripping. So was thinking maybe this simple setup would be good as well.Although cd data is digital, there’s also the issue with physical scratches or dust on your disc which will cause read errors. It will require the cd rom disc drive to retry reading the area again. There’s a few types of error correction mechanisms involved and the ability of the cd rom disc drive’s laser to read the damaged data. The software also has its own part on how many retries it is willing to take before relying on interpolated data or worse case where unrecoverable sound error sips in in the form of empty sound or clicks when the disc is very badly scratched.
So it’s not so simple as ones and zeros.
Not sure how the Sony hardware does it but there are specialised cd ripping software that do function to get more accurate rips
This is true. Mine doesn't even have one even though it has a 3090 and new intelNowadays it’s harder to find computers or laptops that is equipped with a optical disc drive anyways.
For decades of developments, in assembly, c/c++ ... I can confirm that on any drives (CD or medias) there are only ones and zeros and nothing else than some parity data to correct easily reading errors. Even with error corrections, a zero can't become a one => in no case, this can happen, it just would make a disaster.Although cd data is digital, there’s also the issue with physical scratches or dust on your disc which will cause read errors. It will require the cd rom disc drive to retry reading the area again. There’s a few types of error correction mechanisms involved and the ability of the cd rom disc drive’s laser to read the damaged data. The software also has its own part on how many retries it is willing to take before relying on interpolated data or worse case where unrecoverable sound error sips in in the form of empty sound or clicks when the disc is very badly scratched.
The WM1A/Z and ZX300 are pure Linux DAP's. No bloat and with MrWalkman's custom firmware (which can't be done on Android players), you get the best pure DAP.
