CoryGillmore
Something about the Kimber cable I don't see mentioned is the microphonics it introduces and also the creaking from it being so damn stiff. It's driving me mad with more quiet recordings, hasn't been a problem with Tool recordings. It would literally make a blind test impossible since as soon as you move your head slightly you'd know which cable was hooked up from the creaky feedback you'd get. I just hate that the stock 4.4 cable is so damn short!
On the bright side, going back and forth with the stock cable and the Kimber on the balanced output of my Schiit Jotunheim, I can say I do hear difference and the Kimber is much more pleasant. The Kimber most definitely sounds more open and brings the mids out more. I honestly believe I could pick it out in a blind test...if, like I said earlier, a fair one were even possible.
