Well at least on my Z1R, the cable doesn't roll around, even if I try to pull it out.
Sony MDR-Z7 Upgrades and Mods Thread
- Thread starter PETEREK
- Tags
- sony sony-mdr-z7
palchiu
- Dec 30, 2004
Mine also just arrived. Excellent quality, as usually. Only drawback is the used plugs, as the locking is not very confortable to screw in, but it is not a big deal. The plugs fit secure enough without it.
And going balanced is excellent move indeed...
Here's my way to wrok with FAW's Z7 cable.
Screw the nut on HP first, unclockwise twist cable left/right then screw in nut.
And you'll get perfect routing cables.
Maybe few time to firure out how many turns unclockwise should twist.
I'm waiting my Pearstone's locking plugs to try, if better fit I'll replace these ebay plugs.
Hi 5
- Dec 19, 2014
Hey how important is it to use 3M Micropore tape Vs something like 3M Durapore?
Hi 5
- Dec 19, 2014
Being that I already love the Stock sound of the Z7 I decided to mix things up a bit.
I wanted to retain some of that Signature
I went with the 3M DuraPore tape It seem slightly thicker and probably more sounds reflective.
Left all the ports wide open and all Cables stock
Taped only the wire terminals on the drives
Taped in a way to allow the Cups Cross section to remain functional
Sounds Awesome!
Thanks guys!
Sounds Awesome!
Thanks guys!
Hi 5
- Dec 19, 2014
Now, to those who would love even "deeper bass, larger staging, and more trebles, reduced mid ringing". This step is irreversible as the covering net will be damaged permanently. I opened up a driver to experiment it, but there was no way to remove this filter other than cutting the net a little
"remove this center lense filter". Be warn, Do not do this before the previous dampening mod. Once again, do this at your own "risk" as I won't be held responsible for the damages that you have done to it
I'm having a really hard time resisting this mod..
pretty sure i'm going to do this..
hmm did Sony intentionally dumbed down the Z7.. knowing d@mn well the 70mm could be pushed allot further..
- Oct 14, 2013
hmm did Sony intentionally dumbed down the Z7.. knowing d@mn well the 70mm could be pushed allot further.. h34r:
Z1R has a magnesium dome there, and no acoustic filter in the front....what do you think ? Lol
Hi 5
- Dec 19, 2014
Ha Ha! good point
Hi 5
- Dec 19, 2014
Couldn't resist!!
Did the Center filter mod and Pad Mod..
Holy SH!T !!
Holy SH!T !!
- Oct 14, 2013
Couldn't resist!!
Holy SH!T !!
Exactly ! Couldn't believe you had been missing out that long
Hi 5
- Dec 19, 2014
Hehe I know right!
The outstanding quality and craftsmanship of the Z7 makes it a breeze to take apart and mod.
Almost like it was intentional
I've taken them apart a few times now and haven't added a single scratch to them!
Thanks Japan!
But.. in my experimental naïveté Inhave created a dilemma..
Whitigir after removing the Center Lens Filters.
The Z7 sounds amazing but now has to much Detail!!!
Any recommendations? I think ill create a few interchangeable felt style filters that will velcro on..
:-0
Thanks Japan!
:-0
- Oct 14, 2013
Hehe I know right!
Thanks Japan!
:-0
That is a good idea. I have not experienced any of the different filters at that spot yet. You may want to help. Yes, Z7 is a tank. I like details a lot, me leaving it open was what I loved so far
Hi 5
- Dec 19, 2014
Appreciate the feedback! I'll do some experimenting maybe I'll get use to it.
I'll post some more photos Later. On the progress
Hi 5
- Dec 19, 2014
For Anyone considering doing the Center Filter Mod
Hi 5
- Dec 19, 2014
Sharks with freakin Laser Beams !!
You have been warned !!
but it's awesome =)
but it's awesome =)
Hi 5
- Dec 19, 2014
Filter Mod. Continue on page 17
