BIGHMW
- Nov 26, 2007
I was just wondering if any of our fellow Head-Fi'ers out there own a pair of the Sony MDR-NC300D Noise Canceling Eaphones? I actually ordered, received and tested them, and I know how the majority of you thought the MDR-EX700SL/LP sounded kind of flat (I did too, find them a bit flat), even with the EQ boosting the bass, but I have a bit of surprise for those that thought that these NC-based IEMs, (which incorporate the same 16mm driver the 700's do) would be the same SQ-wise....
IT ISN'T.
Now let's go on to the review:
The Package And What Came With It:
The box it came in (straight from Japan, shipped EMS) presents these matte black and chrome-like IEM's throught the plastic window on the box. it also came with a Sony AA battery (I myself use Energizer Ultimate Lithium), as well as the same 7 sets of silicone-hybrid eartips as did the EX700, and also an airline plug adapter, 1.0m extension cord, a velvet pouch, a cord wrap, and a beautiful leather (or leatherette) case to hold them in (minus the spare tips). Also included was the paperwork (all in Japanese at that) involving the warranty and user instructions.
Sound Quality:
I actually found the 300D's to be a bit better than the 700's, as far as SQ and controllability were concerned. the noise canceling, (which BTW is digitally self-adjusting for changing environments) within certain frequencies, has the ability to cancel a whopping 98.4% of all noise at a rate of 18 dB of noise canceling power surrounding the user.
The stats show that this has a really good 103 dB SPL at only 16 ohms, compared to the MDR-NC60 Headphones 100 dB at 100 ohms (with NC off) and also only 102 dB at 40 ohms (with NC on)... Hence me having to use a FiiO E5 with my measly 5 mW NW-HD5 (or any other Walkman for that matter) for that extra volume boost whenever I use the NC60s.
Using With Line-Out:
As for using it with a line-level output as an external amp, I tried it with NW-HD5 set at line out, and got nothing more than distortion. The NC300D was not designed to be used this way despite the fact you would think so because it has its own onboard volume control.
Extra Features:
Obviously as mentioned earlier in this review, this set of IEM's uses a digital processor with 3 different versions of noise canceling, which changes automatically as you travel from one environment to another, and also features the previously-mentioned onboard volume control, as well as buttons for optimizing the NC capability, as well as a monitor button which mutes the audio so you can pick up a conversation, and also a sound switch (user-adjustable) that has a bass boost function, as well as a movie mode, and also a flat mode (EQ-dependant on only that of the player being used).
Build Quality:
It also has the convenience of a much shorter plug (compared to the MDR-NC22) from the main NC controller (more on that in a moment) to a (perhaps) remote-control jack, and since I use a remote-controlled unit (like my NW-HD5), I found it very convenient for me as opposed to the NC22.
As for the famous (or infamous to most of you) J-cord, I have had no problems with them over the years, and as for the lead from the phones where the cords themselves meet to the battery box, yes, I did find it to be somewhat over-excessive, but it also came with a Sony cord wrap to somewhat shorten the cord a bit.
As for the main unit itself, it is well constructed (I believe it's made out of aluminum) it is a bit heavier build than that of the all-plastic NC22, but this mainly is because this unit takes a (the NC22 takes AAA) AA battery, but this also makes the box heavier, and even with the included (and detachable) lapel clip on it, it still weighs a bit heavier than any of my remotes that I use.
Overall:
Well worth the $300 USD I paid for it, but, you can only get them from Japanese retailers (you'll find most of them on eBay or perhaps through Bluetin.com), as this is (so far) a Japan-only model.
As for the fate of my MDR-EX700SL IEM's and my MDR-D777SL and NC60 cans, I have thought about putting them on the market, if you guys have any ideas otherwise, please mention them on this thread.
(Pics coming soon)
Thanks,
Ray Jackson
IT ISN'T.
Sound Quality:
Extra Features:
Build Quality:
Overall:
(Pics coming soon)
Thanks,
Ray Jackson
