For those familiar how is comfort level compared to 1A? Are pads smaller and clamping tighter?
Sony h.ear on MDR-100AAP - $199 'Hi-Res Audio' Over-Ear Headphones
- Thread starter XERO1
inthere
- Apr 11, 2012
I'd say the 1A is more comfortable but the 100aap is very comfortable too.
The 1A has slightly bigger ear pads and they seem a bit softer too.
This isn't confirmed (I don't think) but I think that these headphones may be wired internally for a balanced connection. I got a balanced cable for my MDR-1A's (as it has been confirmed that those are wired for balanced) and just for the hell of it, I plugged that wire into the 100aap's. The wire worked perfectly and the headphones sounded even better though the balanced wire.
hey....just got the MDR-1A. Curious as to what type of cable you have and whether you noticed any improvement in sound. I really like the MDR-1A so far though, but obviously not against making them even better.
Also, how do you rate the 100aap v. the MDR-1A?
thanks
thanks
I got the cable from Surf Cables. The cable didn't change the sound signature of the headphones, but there was a slight increase in sound stage, layering, and detail.
I've only been using it with the Cayin N5 which doesn't have dual DACs, only dual amps. The main advantage in using the balanced on the N5 is the extra driving power and current, which the MDR-1A's really don't need. If the player had dual DAC's for each channel as well rather than just dual amps, then I'm sure there would be a bigger improvement in the sound.
I think the 100aap has tighter bass and slightly better clarity, but I still feel the overall sound of the MDR-1As are better.
arcbodom
- Feb 2, 2016
..I agree with the tighter bass and clarity. Sounds more detailed compared to my mdr-1A but less than the shure srh840. Bass is faster as well.
I have the 100aap to compare to the 1A and they are fantastic. Vocals are more forward and the bass is cleaner and punchier. I still really like the 1A - they are more comfortable and I kind of like that deep, rumbly bass. I am torn between which one to keep. They are too similar to justify keeping both. I am leaning toward the 100aap because it's $100 cheaper and they are not too far behind the 1A in the comfort department.
Sony has a real winner in the 100aap. Surprised I haven't seen that many reviews. The sound quality is incredible given the price.
Mickice
- Oct 8, 2012
I am disappointed by the lack of reviews too.
329161
- May 5, 2012
Just have a read through this thread. With all the hyperbole you'd think they were better than hd800s or something
Mickice
- Oct 8, 2012
If you're not having the same feelings, move along, many phones released daily. We wish you better luck in the future bro.
Not everybody has $1,500 to drop on a pair of headphones. I wouldn't have a clue what the HD800 sound like and that's fine. Nothing wrong with people expressing how much they like this one.
cocolinho
I own both HD800 & 100aap --> love both for many different reasons
329161
- May 5, 2012
Just providing a balanced point of view so people would make a more considered buying decision than what may be possible based on the views of a few in one thread in one forum, that's all. If you like them, then my opinion shouldn't matter to you.
To be honest I am fairly new to the world of higher quality headphones. I have had a HD598 and V-Moda for over a year now, but I've tried a number of headphones over the past 6 months (mostly open ones), including Fidelio X2, AKG 712, Grado 325e, Nighthawk, HiFiMan 400s, and Oppo PM-3. They all have their strengths and I can easily see why people favor them (the Nighthawk being my favorite of those), but if there is anything I've learned it's that price doesn't necessarily mean you'll get a better sounding headphone that pleases your ears. When I first tried the 100aap I was astounded at how good it was for only $200. It is easily comparable to the Oppo at half the price. Yes, the Oppo might be technically superior but it's a bit too clinical sounding to me. The MDR 1A and the 100aap both have a super smooth tone to them that I can listen to for long periods of time. I've decided that I am not much of a fan of the treble leaning, ear scraping sound favored by most audiophiles. It's just not natural to me. Plus, I have yet to try a headphone that matches the comfort level of the Sony models.
Hey guys, I dont know if this has been mentioned recently, but as far as ive gone through the thread no one has given any definitive explanations about the pads.
MDR-1R pads are of a similar size and both fit very comfortably around the ear, but you cannot switch them. They both are clipped onto the baffles via plastic tabs, and the tabs are in very similar positions, however the 100AAP tabs are across the middle of the pad, whereas the MDR-1R pads have tabs at top and bottoms of the pads.
I wanted to know so bad I got both.
