groovyd
- Jun 29, 2012
I won't buy any more headphones unless I can get them calibrated... just sayin
How does this sonaworks work? Will it improve the sound quality of focal elear???
Just pulled the trigger on a pair of calibrated HD800s
U can try their Beta version True-Fi, it has the Focal Elear on their list now. I assume it will be on their Sonarworks soon. I also see it on their beta Android app: Soundigo
https://sonarworks.com/truefi
They also added: - We've just launched a new True-Fi beta build, which adds an interesting feature - age related hearing loss compensation!
I just installed True-Fi beta a couple days ago. The installation is pretty straight forward, download, install and voila! Works out of the box, no more tweaking required. What it does is that it installs an audio driver interface, all audio signal goes through the True-Fi app before it is routed to your chosen output, in my case the Jot DAC. Pretty easy and painless process, no harm giving it a try!Tnx for answer.Does it work with tidal?
Received my HD800s and to be honest I prefer the HD650 for being much much flatter. I had expected the 800s to step up the 650 game but I was wrong. Construction and comfort is good though and it has huge soundstage but requires considerable compensation.
I thought you were getting the 800. (Wish Senn would've used another letter for the upgrade besides S). The 800 needed EVEN MORE correcting.
Bern
Not sure there's a curve yet for the HD800S.....just the 800. Maybe it's been added...been a while since I last looked.Try the average curve. Then you will know if it is a bad profile.
