RudeWolf
- May 29, 2011
VSTHost is anything but intuitive!
So you need this - http://www.hermannseib.com/english/vsthost.htm
It will make an emulated environment which will be able to use VST plug-ins.
And this - http://vb-audio.pagesperso-orange.fr/Cable/
It's a utility which will make it possible for your system to communicate with VSTHost and treat it like a DAC, while actually it will be a proxy between a DAC and your audio output.
Keep in mind that our plug-in will introduce a minimum of 1.13ms of delay, which makes it clunky to use for video. Tidal on the other hand should be just fine! We currently have a zero latency in the works, so stay tuned!
