agate
- Aug 28, 2011
http://www.amazon.com/Sennheiser-HD595-Performance-Premiere-Headphones/dp/B0001FTVE0/ref=sr_1_10?s=electronics&ie=UTF8&qid=1314571348&sr=1-10
http://www.amazon.com/Technica-ATH-ANC7B-Noise-Cancelling-Closed-Back-Headphones/dp/B002HWJT1A/ref=pd_sim_e_1
http://www.amazon.com/gp/product/B0042A8CW2/sr=8-2/qid=1314571032/ref=olp_product_details?ie=UTF8&me=&qid=1314571032&sr=8-2&seller=
Which has the best quality? I'm not too concerned about bass.
I'm a bit of a noob when it comes to being an audiophile, so if you could put it into a 1. 2. 3. (1 being best, 3 being worst) format, it'd really help
I listen to mostly rap, hip hop, alternative, and some rock. My budget is $250, so if you know of any headphones that are better than the ones listed (and within the price range), tell me!
