Mediaogre
- Feb 7, 2010
First time Head-fier. I'm so glad I found you guys when I did. I'll try to format my questions so I don't appear to be the worst forum newb on the Internet today.
I plan to pair an amp with SE530s and a Zune 80.
General Questions:
-Will a quality amp reduce or eliminate the hard disk "farting" and other electronic device noises I'm hearing?
-I've heard that some amps pick up electronic interference from cellular phones, etc. Do they all do this, or is it just the less expensive models?
Specific Questions:
-Is there an amp that compares with Ray Samuel's Shadow for less but still has high build quality? (I know this is a stretch. Ray's elegant design and attention to detail seem unmatched. Portability and quality of construction is key. And the Pico Slim seems unobtainable.)
-Can someone explain the Shadow's lack of a need for a gain switch?
-I've read that some amps pop when powered on. Is this something I need to be concerned with, or is this a symptom of cheaper components?
-Does anyone have feedback on the Shadow and IEMs?
Thanks,
Greg
General Questions:
Specific Questions:
Thanks,
Greg
