Soldering Flux
Sep 22, 2008 at 7:04 PM Post #16 of 40
I cant believe I soldered a zillion Leeds and wires and no one ever said "hey, use some flux". Everything I worked on was small though, I can see working on bigger stuff like large cables and what have you.
Sep 22, 2008 at 7:17 PM Post #17 of 40
This was for very small gauge coax wire connected to acoustic guitar pickups. It allowed the tinning to happen much faster to the inner insulation would not melt.
Flux for electronics is (typically) more for repair work than initial soldering. I also add some to my braid when using it for desoldering, which makes it work much faster.
Sep 22, 2008 at 9:42 PM Post #18 of 40
As I plan to build my little project with specs a bit on the overkill side, I'm still looking for the Kester 1544, but will keep in mind the MG Chemicals No-clean Rosin flux from Sayal (Sayal has a location just minutes from my place).
I'll alos drop in to the Sayal location near me to see what other flux pen/liquid products they have. I'm not a big fan of their website (not descriptive enough).
.:..:::Jugtree
Sep 23, 2008 at 1:22 AM Post #20 of 40
The Kester 186 RMA Flux Pen is awesome.
Makes life so much easier. Especially with smd work.
Sep 23, 2008 at 1:48 AM Post #21 of 40
Very good tip.
Oct 27, 2008 at 6:30 PM Post #22 of 40
I was over at my local electronics parts store and they had some paste flux (in a small tub) and a liquid flux (in what looked like a spray bottle).
Which would work better for my first SMD? (Mini3)
Oct 27, 2008 at 6:51 PM Post #24 of 40
Originally Posted by Pars /img/forum/go_quote.gif
Liquid, but jar/brush would be better than spray. Even better if they have the Kester Flux Pen...
That's all they had unfortunately. It said RMA Liquid Flux. If I buy it, any ideas where I could locally source a fine tipped pen to put it in? (to make application very precise). Or in the alternative, I guess I could just stick a brush in the Flux with the top off.
RMA needs to be cleaned thoroughly though, right?
Oct 27, 2008 at 7:10 PM Post #27 of 40
My recommendation:
Digi-Key - KE1804-ND (Kester Solder - 83-1000-0951)
I was hoping to find something locally as I wanted to try and work on the SMD today
Out of the options above, which combo would probably work best as an alternative?
Flux Paste (w/ Brush)
RMA Liquid Flux in Spray Bottle (w/ Brush or maybe squeeze bottle rather than spray)
Oct 27, 2008 at 7:30 PM Post #28 of 40
Or maybe I should even just get this from Radioshack - Rosin Soldering Flux
I assume I just tack a little bit on each pad before placing the chip on. I guess what i'm confused about, is the Rosin Soldering Flux all I need? (does it act as solder itself as well) or do I just put a little dab on each pad, then solder the pins as normal.
Oct 27, 2008 at 7:41 PM Post #29 of 40
You still need to solder it on.
Flux is just a chemical that chemically reacts and cleans your components when heated to help the solder to 'wet' onto the component.
Quite frankly, you don't really need extra flux to solder on soic-8 parts. Extra flux would definitely help, and I'd recommend it to anyone, but if you're eager to do it now, there's already enough flux inside the core of your solder to get the job done.
I like the flux pen myself because it's easy to store away.
Most any flux will work..(you don't want acid flux). Some flux are mildly active, and will cause problems if not cleaned off, but you should clean the flux off the board regardless. I heard rosin flux was a little more stickier than liquid flux.
Oct 27, 2008 at 7:41 PM Post #30 of 40
I'd go for the RMA flux myself, although I didn't look at the ratshack link. Flux is a cleaner which helps the metal (copper) accept solder; so yes, you still need to add solder (a small amount).
