Hello gents. Been gone for a while, but I see that you guys have been talking.
Yes, SOHA originaly stood for Stoopid Opamp Headphone Amplifier because when Bill proposed the idea I thought it was stupid. But he and Mark persuaded me that it was worth a try to make a better low voltage tube amp. After a while I decided that I liked the idea of making a good low voltage hybrid.
SOHA II uses the acronym just to keep the lineage of low voltage hybrid. The amp is a natural successor to the SOHA. If the SOHA had tracked the way I wanted it to (and you can go look at my posts on the headwize threads) it would have had a discrete buffer very quickly. I also never liked the trimpot adjustment, but it was there in the interest of making things as simple as possible for guys who wanted a tube amp that wouldn't kill them.
The amp board is 160mm x 115mm and will fit the Hammond cases that dBel84 mentioned. It has a built-in PS, just like the SOHA, that provides the LV split supply, the B+ for the tube, and the heater supply all from a single 15-0-15/1A transformer. You can walwart it, but a normal walwart will not work because it doesn't have the CT supply. All of this has been discussed in the orignal SOHA threads and builders have bought walwart boxes to put the toroids into. You can do that here also while using the shorter Hammond box.
I've probably missed some things in this response.
