Thanks, Joe.
I have another question for him, or anyone here with high level EE knowledge:
## Is there any way (even costly / difficult) to lower the output impedance of this amp?
I have the unfortunate need to use these with both studio cans and low impedance IEM's. In fact, my favorite IEM's are the Shure SE846, and they are only 9 ohms. The SP200 output has been measured independently as being 1.3 ohms. That's not nearly as low as amps like the O2 amp, the JDS Atom, etc, and it's a HORRIBLE match with my 846's. They sound AWFUL. (harsh, no LF, etc)
I stupidly decided on my new studio amps based only on testing with 250 - 600 ohms. Now, I literally can't use my IEM's.
I may try other good IEM's that are 16 ohm or more, but I hate the idea of retiring those amazing 846's.
I tried an inline resistor network at 80 ohms, but while this brought back the LF and lowered the distortion, it also killed a significant amount of HF. (resistance is not capacitance.) Ugh .....
So, I'm wondering if there's ANY hope of electronically lowering the output impedance. I know of no amp that comes close to this design, for less than 2-3X the price, so I'm willing to sink some money and time into such a mod.
Maybe change the gain structure, by lowering both the input and the output resistance?
## Maybe a different op amp?
The two stock SP200 gain op amps are OPA1612A.
The Benchmarl HPA4, a $3,000 THX-888 design, uses 2 OPA 564 op amps. Surprisingly, (to me) It also uses a pair of OPA1612A dual op-amps as "error-correction" amplifiers.
The HP4A has a rated output impedance of “less than 1 ohm” Given my SE846’s 9 ohm impedance, that could actually make a big difference to me.
I’d LOVE to know why Benchmark used this alternate 20-pin power ic, and then used what the SP200 uses as some kind of ancillary circuit. What is “error-correction?”
And the obvious questions:
1: Can the OPA 564 be used as a direct-replacement for the SP200’s 1612A? (I suspect not)
2: Is so, might it sound better? - Maybe not. Both ic’s cost about the same $8-$9 each.
3: If so, could it possibly have a lower output impedance? - The HP4A has a rated output impedance of “less than 1 ohm” Given my SE846’s 9 ohm impedance, that could actually make a big difference to me.
