Jon L
For him, f/1.2 is a prime number
- May 20, 2003
I'm curious about your comment concerning the xlr inputs going through additional stage. Evidence?
It's in the linked article re component analysis:
"The section 6 is for sure is input buffer same as the section 4, except it is for balanced input to single ended output converter. The reason for this is because the input at the amplifier on section 3 is all single ended, so even the audio line input is balanced, they need to convert it to the single ended by using the op-amps before go to the volume control and the amplifier section. The op-amp IC are OPA1612A."
