Neither. It is an amplifier without dac and is not usb powered.
SMSL SP200 THX AAA 888 Balanced AMP!
- Thread starter chillihead
Ooops lol. Geeesh meant the benchmark dac. My bad lol. There's my first error for the day.Neither. It is an amplifier without dac and is not usb powered.
I believe it to be a b bus to end the story.
I'm glad I don't have to deal with the volume nob anymore because I have it set to where I use the volume on my Topping D50s. I can adjust it a half a dB at a time which is so much better than having to mess with that crappy one on the amp. I bet they end up changing it in the future on an updated version.
I just bought a second sp200 I'm so impressed.
MadMike
- Dec 20, 2006
Same here - I use my Teac UD-301 to adjust the volume.I'm glad I don't have to deal with the volume nob anymore because I have it set to where I use the volume on my Topping D50s. I can adjust it a half a dB at a time which is so much better than having to mess with that crappy one on the amp. I bet they end up changing it in the future on an updated version.
Delmetrice
Don't you want your source and DAC volume to be at its max and adjust on the amp end?
Edit: I run full optical, so the answer to this question may vary.
Pete Gardner
- May 4, 2017
Thanks chillihead,
Have ordered knob.
Looking forward to sp200 to arrive.
Have ordered knob.
Pete Gardner
- May 4, 2017
Has anyone used sp200 with zmf headphones?
In particular the Aeolus
MadMike
- Dec 20, 2006
I am using the XLR output from my dac, which puts out 4 Vrms - lots of signal to play with. If I run it at max, the amp would go no higher than 8:30 on the volume control due to the sensitivity of my Elear hp and the power of this amp.Don't you want your source and DAC volume to be at its max and adjust on the amp end?
chaotic_angel
helo users, is it true that there is no differences found between BAL & SE headphone output in terms of power and sound?
- Sep 28, 2016
Me me xD. What else do you want to know? It's enough power and without distortionHas anyone used sp200 with zmf headphones?
Power, no difference. Small improvement in 'crosstalk' via XLR outputhelo users, is it true that there is no differences found between BAL & SE headphone output in terms of power and sound?
Pete Gardner
- May 4, 2017
Thanks Tim0chan,
I was checking that they are a good match with sp200.
I currently have Audeze XCs and have been considering selling and getting Aeolus.
Riversalt
- May 21, 2016
Had to upgrade the volume knob to something more beefy. Knurled heavy aluminum!
That adds more weight, more solidity to the knob, no?
