chillihead
Yes, I personally think it's what it needs to polish off an already nice product.
Do keep in mind you will be moving from a closed system to an open one. But yes, if you like the aeolus already, this is a very capable amplifier for the jobThanks Tim0chan,
I was checking that they are a good match with sp200.
I currently have Audeze XCs and have been considering selling and getting Aeolus.
Looking for a dac to pair with the sp200 and HD800 S, any recommendations? Also worth the upgrade to the drop thx 789?
The SMSL SU-8 is a very good DAC at a pretty good price. MassDrop has been pushing it at $170.00.
I wouldn't look at the 789 as an upgrade unless you need the extra power via balanced.
Shane D
@inseconds99,
Just my 2 cents.
SP200 is slightly warmer in tone & the staging is wider with lower noise floor than the 789.
Regarding a DAC, depends on your budget & what you're looking for?
Hope you have a great day !
Not sure if the HD800S will benefit from extra lower. I’m ordering all the equipment today so if the 789 is needed to drive them I’ll invest in it.
looking for a clean dac that measures well but doesn’t cause harshness from the hd800s.
Edit: Oops xD (format error)Not sure if the HD800S will benefit from extra lower. I’m ordering all the equipment today so if the 789 is needed to drive them I’ll invest in it.
If so I'd go with the topping d50s. It's really good for the price that Drop has it for
Should be around the same price as the su-8 but in my opinion it is the better productunfortunately that dac seems to be out of stock on drop, do you know what the price was?
You don’t need extra power ( from 789) to drive the HD800. I own the HD800 and HD600 and the SP200 drive them without any effort, in fact
