- Mar 30, 2012
Is this amp considered a truly balanced amp? If I rewire a Fostex T50RP MK3 headphone to become balanced (Argon MK3 mod), will this be the right amp to make full use of the modded headphone? or is XLR output = SE output without any separation of channels? -Thanks
Channel seperation is a spec, SE an XLR both have a measurable level of channel seperation. With XLR out that measured spec is higher, so the output should be Audibly clearer
The question is whether or not the difference is actually audible to all listeners, if the internals of the fostex t50rp MK3 can support a balanced cable and ballanced wiring then go for it as you'll get the best performance with the XLR
will you hear a difference after that I can't say, power-wise though yes sp200 is more than enough
