Greenears
- Dec 2, 2014
A pair of preamps for level matching are needed too. You can usually find inexpensive used ones on eBay. It helps to get the same make and model.
I don't mind doing that but I was hoping the sources would have volume controls and I could use that to adjust the levels. Otherwise they will say something like "your pre-amp colored the sound and invalidated the test" Sources and DACs are a big part of the test for me, as well as speakers. However I think I have a reference source with volume control, the problem is how to get material onto the second source.
