- Jan 9, 2003
Sometimes an unmarked 2-setting knob is used to switch inputs, other times it is the notorious "high voltage" switch. If it's the latter then usually you want to rotate it the more counter-clockwise position (relative to as when you're facing it directly) for the lower voltage setting (< 300V). You NEVER want to turn such a knob while the amp is on, especially to the higher voltage setting! My tech measured the high voltage setting at 500V+ to the output tube plates, on my old SDS. That was NOT acceptable!
Also, the high voltage setting is too much plate voltage for a 6sn7 (OK for the 6BL7 plates, though who knows about the rating of the caps inside, or whether the 6BL7 heater current draw is OK for the transformer, etc). This voltage setting only affects the two output tubes, not the gain tube (and the position of the input tube on Singlepower amps is not always entirely consistent either). Keep the knob it on the probable "low" setting until you find out more about that particular amp. Mikhail wasn't known for following any kind of standards on any given day.
Again, good luck and hope you can enjoy the music in "relative" safety
My old Singlepower SDS and Headamp Gilmore Reference are the two headphone amps I'll miss the most. Though, now I have a pair of Rogue Apollos to drive my Tannoy Kensingtons and keep me toasty warm at night
Originally Posted by Elizabeth /img/forum/go_quote.gif Whoo HOO I DO have the mysterious knob in the back (it does seem to vary the power to the tubes) I switched to 6SN7s and the output tube you suggested (the 2C51/adapter came with the amp) Too bad the seller sent me a huge pile of 6BL7s I had to steal a pair of 6SN7s from a buffer. |
