Simple Ultrasone HFI-780 mod to increase bass (May also work on other models)
Aug 4, 2012 at 4:31 AM Post #31 of 70
Now the pro 900 can have it's amazing mid bass and as much sub bass as the d5k!
I've got the D5000 and love that sub bass.
Aug 4, 2012 at 5:05 AM Post #32 of 70
Trust me, I've spent 2 weeks trying to EQ and DSP these the way I want them too, but it always started distorting when it got close to how I wanted it to sound (I love me some bass long time).  When I did this, the results were so good that I just had to post them here :).  And I seriously doubt this is irreversible, all you have to do just block the three holes with anything; tape, sticky tack, etc.  This mod + EQing =
It is pretty difficult to distort unless it is insane bass. Make sure that you haven't gone above 0db when doing digital EQ.
Aug 8, 2012 at 8:39 PM Post #33 of 70
Just for fun I decided to try this mod on my DJ1 Pro and it worked fine. The bass is slightly increased without any loss in clarity and without any noticeable affect to the mids or highs
I just tried the mod to my PRO550s, opened 2 holes. There was a slight bass increase but I felt an overall loss in quality : / everything got kinda.. airy and a little more noisy.
Nov 10, 2012 at 12:24 PM Post #36 of 70
ok so i couldnt stop thinking about this mod, so i tried.
as scared as i was, coz ive never opened up a pair of headphones before, i tried it.
and can i just say wow!! the bass is so much better now!! and also i think i stretched the pads a bit trying to get them back on, and maybe its just in my head but they feel more comfortable now too.
thanks for sharing this mod :D
Dec 1, 2012 at 7:09 PM Post #38 of 70
I used to have a pair of M50s. I think you would have to drill extra holes since there are no holes covered up.
Dec 5, 2012 at 9:16 PM Post #40 of 70
Bump.
Or how much of a bass increase does this cause? 50%? Double?
I would think that the process of doing this mod on the 580 is identical to doing it on the 780 or the 900 pro.
It would take a lot of math and physics to calculate how much this mod increases the bass, but as many have reported, there's a noticeable difference.
If you're not afraid of voiding your warranty, try the mod and report back.  It's reversible.
Dec 5, 2012 at 9:29 PM Post #41 of 70
Subscribed....for potential future reference.
To those that posted the technique and photos,
Dec 21, 2012 at 11:54 PM Post #43 of 70
pics? What pads are there to re-wrap?  The earpads just snap back in place...
It should be easy enough to solder them back on, just be quick (minimize heat transferred to the drivers) or you might damage the drivers.
Mar 14, 2013 at 5:00 PM Post #44 of 70
Just found this thread and I'm very excited. When I received my 780's it sounded like there was a piece that was loose and rattling throughout the left can. Not sure how that affects the sound but to me, the bass is entirely lacking. When I play music through these vs. my desk speakers or my (recently acquired) V-Moda M 80s, it sounds as if there is nearly zero bass at all. Definitely "punchy" but people describe is as "powerfully punchy" and "strong" and to me, it sounds exactly what my desk speakers sound like when the bass is disconnected. Even when I turn up the EQ it just sounds distorted at best and still entirely lacking. Could the loose piece (that seems to no longer be loose as it no longer rattles around) have affected the bass? I am looking forward to modding my 780's as soon as my friend (whom I lent them to) returns them to me next week and will report back as to whether or not it helps.
Mar 14, 2013 at 7:42 PM Post #45 of 70
Have you tried opening up them yet? Just follow the pics and should be pretty easy. What you describe is not "normal" - lack of bass (on this cans) and the ratlling.
