Apr 19, 2011 at 2:07 PM Thread Starter Post #1 of 21
Jay_C
I have "Shure SRH440" the Ear Cushions are on there last legs.
Im looking to replace them with the ones that are on the "Shure SRH840" Replacement Ear Cushions   - -  HPAEC840
Thanks
Apr 19, 2011 at 2:44 PM Post #4 of 21
hi thanks for the reply
ye the first thing was if the fitted the 440's ok
also what benifit might i find with them
thanks
+ comfort, better isolation...probably soundstage.
Apr 19, 2011 at 3:46 PM Post #7 of 21
Thank you so much for you help
this is only my 3rd thread i have posted on the forum
all have being as helpfull as this.
try and guess what im off to order
Apr 19, 2011 at 4:23 PM Post #8 of 21
I'm glad it was helpful, keep us posted.
Good luck man!
Apr 27, 2011 at 7:56 PM Post #10 of 21
I found they also increase the bass a surprising amount. The SRH440's with 840 pads are actually much much bassier than the stock SRH840s. On certain songs, it's Ultrasone like. Whoever said SRH440's were bass deficient definitely didn't have 840 pads on them.
Jun 28, 2011 at 4:13 AM Post #11 of 21
Are shure srh840 earpads deeper than 440 earpads? this is because my 440 earpads are incredibly shallow which make me feel so uncomfortable when my ears toucing the cover that protecting the driver
Jun 28, 2011 at 4:19 AM Post #12 of 21
The pads are maybe 3/4 inches deep on my 840s. They compress a bit when you put them on.
Jun 28, 2011 at 4:39 AM Post #14 of 21
so is it deeper?will your ears touch the driver cover?
I don't own the 440s. I took a rough estimate of the "deepness" of my 840 pads so you could look at your 440 pads and tell if they might be deeper. IMO looking at them I don't think/know if the 840 pads will get your ears off the driver.
