I use 10 ft extension cables with my Audeze LCD-X headphones, Shure SRH-1540 headphones, and Shanling IEMs, and had detected zero added noise with any of them. I think only a VFD, a big motor, or a microwave oven, would introduce noise in most households. It is correct that balanced is preferable for long cable runs if there's added noise associated with this, but it's meant for a studio environment where there's lots of electronics around. I just don't happen to run my cables by things that would introduce much of it. Though balanced does offer you more power, I don't buy the extended dynamic range argument, unless you had been severely underpowering your headphones with the single ended configuration (like 30 mW with those headphones). If you're listening music that doesn't have a lot of low end, you won't need as much power as you would with rock or techno music. I've lived in Ontario, Alberta, California, and Texas (in that order). In all four places I had used Digikey to buy mail order electronics parts. That's probably your best bet, on the "rock". I think I have a four pin balanced headphone connector in storage from 2018, in the same box as my variable heat Weller soldering iron. I had decided not to continue making a homemade cable. I just feel that the marketing people have been overselling the benefits of balanced headphone connections (and that salesman had HiFiMan HE-1000s). I also don't use balanced patch cables (my bulk has three conductors and a foil shield, with which I could make XLRs or RCAs). The professional microphones at Guitar Center where I had gone today, all had XLR connections, because you are more likely to pick up noise in a lower voltage situation.I’m of the understanding that longer cables are subject to significant noise, acquired along the distance between amp and driver. Balancng is designed to remove it, as well as provide the extra headroom and, I imagine in some cases, provide for some extra dynamic range. I guess the real question is about what Shure may have done with the included SE cable for ensuring the noise acquired is not significant.
Part of why I’m here is to learn from others because I’m far from learning these types of things first hand in Newfoundland. Although, I must say I haven’t heard much in this tread about SRH1540 Head-fiers needing to lean on balanced cables. Just anecdotally noting, from what I hear from my (broken) SRH940’s, I probably won’t need to spend the extra $$ either…
… but then… this is so much fun!
I'm trying to sell my SRH1540s and wish I had gotten SRH940s instead, for their resolution and foldability. Neither of them can match Audeze bass (but then again, they're less than half the price). My $500 IEMs can out-resolve even the LCD-X, but they have imaging, soundstage and timbre problems. But still, I am likely to take those on a trip.
