Mark Up
On my third try with these headphones. The first two with only stock pads so I couldn't get past the same impression Tyll had of a little too much high end and lacking low sub bass. After extensive and horrific bending of the bands (nearly unbreakable) I got them to fit on my large head, with just the right angle and clamp. Their stock pads were still a little small in the opening. I have oily skin so the alcantara over time can absorb too much of it so I needed a solution. I wonder if anyone else here has put the SRH840 pads on them before?
They fit with larger ear openings and better to reach my distant ears, and can be wiped clean. Being a bit thinner the ears are closer to the driver while the pleather/leather whatever makes for a slightly better seal. Ears will get a bit warmer faster. Still not the most noise isolating but adequate. Those slightly tame the highs without making them dull or lack detail. High mids and mids are just right, and fully represented now. Their light mid bass bump is still there or slightly lower, and the sub bass is just slightly more extended and not boomy.
UPDATE: I put the stock pads back on after gently stretching them a bit. They just make it to where my ears are not touching the sides. I notice the warmer sound with fuller bass and less aggressive highs is still there. I put those other pads on right after a very long burn in with bass heavy stuff. I believe the warming was from the burn in, and not so much the pads, as I like they way the sound stock. They still lean toward having good high mid and high end detail, the mids seem less recessed and they are a trustworthy sonic reference.
