TYATYA
Today I felt myself one step closer to KSE1500. I read on a German forum, from a Shure guy that there is no analog->digital conversion being done on the line-in channel, which is great. That means an external DAC will be used to its full potential - if ever it is needed (and for me this would only happen in office or home situations). Can someone confirm that?
Confirmed. Surely.
It is pure analog path line in.
The dac doesnt act in audio path unless you use EQ. A fully parametric is fine but that is NOT the one in kse. Kse own a semi-parametric (for me, as a crappy eq).
If eq turn ON then audio path for line in will be analog source - ADC - eq processing - DAC - opamp - elect. drivers.
There are 2 things is NOT CLEAR here in this thread : Pad input and Limiter for analog in.
Imo, it IS digital processing to decrease signal strength to -10dB or -20dB.
But some one will say that is pure analog w/o digital process. Hm, how to do it w/o physical varistor ?
Btw Input pad is seem no change the sq (to my ears) but Limiter does it in negative meaning
