- Jul 7, 2013
http://www.amazon.com/gp/aw/s/ref=is_s_ss_i_0_5?k=spinfit&sprefix=spinf
Ordered the CP-800. Thx...
Received my Spinfit silicon tips today and my expectation going in was nill as I have always been a Comply Foam guy. These things are amazing, seal is just as good IMO, insertion and obtaining seal is much faster and easier as well.
Plus so far they seem to be more comfortable. Looks like I have found a winner, great $9 Amazon investment.
I tried the spin fits when I first received the kse, but I kept going back to the Shore Olives. I usually prefer silicon tips too so I was surprised I didn't like the spin fits. I'll give them another try though
Has anyone tried the JVC Spiral dot rolling mod for these?
For the dumb and uneducated fools like me, can you explain what this is?
This or Layla II + AK380 will better choice for everyday listening
These sound amazing, but IMO are not that portable. Are you looking for something you will use when on the go or more for home listening?
On the go mainly. Layla +AK is much more pricey and if the shure sound better, maybe it's best I go with them ?
My bad, I read your question wrong. I thought you had the AK already, and you were wondering if you should get the shure or the Layla II to go with the AK380. What would you use as a DAP to go with the Shure?
How does the memory wire on the KSE1500 compare to the memory wire in the stock SE846 cable? I had the SE846's memory wire break after only a few months of use.
