I got the AONIC 50 for 3 days now. I enjoy the sound quality. I'll write up my review later. Right now, I have this issue with sound glitch.
Issue 1:
After I turn on the headphones, and start playing music, there is a glitch (where the sound stops and starts for fraction of second). This occurs at 14-15 seconds after the “Power on… Connected” message ends.
If I wait after 15 second to start playing music, I won’t hear this glitch.
This is quite repeatable. This occurs more than 50% of time. This has happened to all devices I have (iPhone, 2 different iPads, 2 different MacBookPro).
Because it occurs so often, I used a timer and it is always at 14-15 second mark.
There was 1 instances that at 14-15 second mark, even though I’m playing music already, I heard the message “Connected” again. So I thought it might have to do with headphone trying to pair with 2nd device. So I did trial and error of connecting to 1 vs 2 devices. But I can almost always (>50%) produce this issue, regardless if only 1 or 2 devices are paired.
I want to check if this is design issue or issue with my particular unit. Do you guys have this problem?
Issue 2:
This 2nd issue occurs rarely. I get this same glitch (where the sound stops and starts for fraction of second) intermittently. Sometimes it is just a single glitch. At first, I thought it has to do CPU load and my music player (Spotify) glitched.
Then, there were 2 instances where glitch kept on occurring every minute or so. Once on my MacBookPro and once on my iPhone.
First time, I think I just power off/on and it went away.
Second time, it occurred after I noticed issue #1. So I tried to to do some trouble shooting. I believe the issue stopped when I unpaired 2nd device. But this occurrence is so low, I don’t know if the root cause is indeed the 2nd paired device.
Any suggestions or idea what is going on? I'm debating if I should exchange this unit. But then I have to go thru the hassle of return shipment.
