garmaiz
- Aug 28, 2010
Hi guys. I am writing to see if I can get help. The problem that I am having is that the left monitor on my Shure se420 only works when you hold it in a certain way (like forcing the cable downwards from the plug). When it is straight it doesnt work, when you hold it down from the plug it works fine... There is any way to fix this? The phones are out of warranty, so going to shure is not an option...
Thanks
Thanks
