Should I upgrade my Sennheiser HD515 to HD558?
Jul 28, 2012 at 9:04 PM Post #32 of 39
Just IMO but I hate the hd558 cable and adapter for portable use :frowning2: . And there's pretty much no replacement cable for it (other than the stock version). Really wish I had known this before I bought them...
Jul 29, 2012 at 12:02 AM Post #33 of 39
you can try to buy a short male to female cable to help relieve stress of the 3.5 port on your portable device, i use a cable splitter that has 1 male port and 2 female ports which total to a 3 inches long cable, these stuff are really cheap so i hope this helps
Aug 12, 2012 at 12:55 AM Post #35 of 39
OK, after using it for a while.. I find HD558 too be lacking in bass, the high and mid is better than my HD515, but the bass is not to my satisfaction..
I think I'm going to sell my HD558, I think I'm not happy with it.. it may not be worth the upgrade from HD515
Aug 12, 2012 at 2:30 AM Post #36 of 39
well the bass on the hd518 is better, bit since its probably similar to hd515, probably its best to stick to the hd515
Aug 13, 2012 at 2:53 AM Post #38 of 39
If you listen to them long enough, you'll eventually hear them as having a good amount of bass. There will be a psychological change, and burn-in will help as well (though not much). You may want to wait a little longer and see.
