Davesrose
- Oct 20, 2006
I found the 414 pads cut down on some of the harshness. People told me that they would add bass, but to my ears they didn't. So all in all, I like the bowls tonality better. If I have the 414s on my 325i, well they're just a bit softer then my HD595. I would not recommend the HD650 for metal.
If after the 414 pad you find you're still not liking your Grado, the only Senn that might work is the HD595. The 650 is too soft in detail and high in bass for any metal. It is worth demoing any new headphone to see if you'd like it for metal.....I know Maza will chime in and say the HD595s are terrible
But actually with the sound samples you gave me Maza, the HD595s sounded better then the SR60 when I compared those. They had more impact, even though there was a bit stronger bass. Beyers will be too bassy, as well as ATs. AKG may work, though they have a large soundstage. 325i though...they're even more detailed then the SR225..would be really hard core for metal.... I don't see why you don't have those already, Maza
