Originally Posted by Oink1 Jesus! - didn't realise it was that late
Lol, good to know I'm not the only guy in the UK who doesn't know when to call it a night
Anywho, my plan right now is to pull the speakers off the wall tomorrow and see how they sound - they might be completely different. My main problem right now is they lack midrange - this could be due to the wall humping though.
If it doesn't improve, I'll nip down to paul roberts hi-fi to see what I can do with an exchange, but I think they seem to not stock monitor audio speakers. I think then, I'll go to Radfords hifi (aka, the money pit) to see what they have, as they seemed to know more of what I wanted in there and offer nicer kit.
Originally Posted by shuurajou but it's going to be difficult for me to get them away from the wall, because there isn't really anywhere else I can put the buggers.
In this case what you hear on dem room may sound different with your placement. If your mission has a duct port located in back, bass will overpower the sound balance. Try to close or plug that port tight and see if you like the difference.
Originally Posted by Nak Man In this case what you hear on dem room may sound different with your placement. If your mission has a duct port located in back, bass will overpower the sound balance. Try to close or plug that port tight and see if you like the difference.
I'll see what I can do, I think I can live with a few wires here and there; maybe a few speaker stands randomly dotted in the room - if it sounds good enough
Just checked and they do have 'anti-turbulence rear mounted port'. =) Is there any port plug supplied with the speakers ? Give it a try as closed port will change sound quite a bit and who knows you might be able to get away with no stands and keep current placement.
Originally Posted by Nak Man Just checked and they do have 'anti-turbulence rear mounted port'. =) Is there any port plug supplied with the speakers ? Give it a try as closed port will change sound quite a bit and who knows you might be able to get away with no stands and keep current placement.
Unfortunately there's no plugs supplied with them. But kind of, isn't a wall behind them having the same effect?
Quite the opposite, a tight closed port mean damped bass while wall reflection reinforces bass. Yes, lack of room interaction make phones a much more friendlier world. =) In some cases speaker placement + room dimension play very significant part on how speakers will sound.
Originally Posted by Nak Man Quite the opposite, a tight closed port mean damped bass while wall reflection reinforces bass. Yes, lack of room interaction make phones a much more friendlier world. =) In some cases speaker placement + room dimension play very significant part on how speakers will sound.
Well, my almighty Sharp MD-X5 used to rock this room!
I appreciate every bit of help & time you and everybody else put into this thread. It's much appreciated. I hope the outcome of all this is worth it
wondering this for myself too. In the case of a rear port, would it be possible to use some acoustic absorbing material on the wall and have the speaker about 6-12 inches away?
Originally Posted by pne wondering this for myself too. In the case of a rear port, would it be possible to use some acoustic absorbing material on the wall and have the speaker about 6-12 inches away?
I would think depends on individual speakers. I used to own the Paradigm Mini-Monitor, which is rear-ported, and it was booming big time even with 12 inches (or more) away from the back wall. Which is one reason why my current speaker is front-ported.
Well, I did try pulling the speakers off the wall a bit, which was a very small improvement. But, then I found an option to set distance from listening position. It was set to 3.6m. Which, I'm more around 2m away from the speakers. So, I reset the settings appropriately and WOW, alot different than before. I'm still in a testing listening phase but it seems to be mucho improvement right now.
Originally Posted by shuurajou Well, I did try pulling the speakers off the wall a bit, which was a very small improvement. But, then I found an option to set distance from listening position. It was set to 3.6m. Which, I'm more around 2m away from the speakers. So, I reset the settings appropriately and WOW, alot different than before. I'm still in a testing listening phase but it seems to be mucho improvement right now.
They're sounding better then? - going to keep them?
Although they've improved alot, I still don't know if I'm going to keep them. I'll give them a final listening tomorrow morning, then make my decision.
I'm going to give them a bit more of a detailed listen tomorrow, to see how I feel. In the mean time, here's a list of speakers that I've put together on some I'm considering getting instead (if I can).
It would be great to hear on anybodys opinions on these speakers, or any alternatives that are within the same price range.
A few models of speakers I'm currently looking at instead of the V61's are:
