Mastergill
- Jun 17, 2003
Hello boys and girls,
OK, I gonna try to make it short and sorry for my broken English. This story began in the end of January when i decided to ask Cardas about the possibility of a custom HD-650 cable made with some Neutral Reference cable. I mean the 'standart' Cardas is very good and i could have stop there...but looking at my setup it was obviously the weak part. Having some Golden Ref. as IC, I wanted something of the 'same quality' or as close as possible for bringing the last bit of musical info to my beloved HD-650 drivers.
Brian from Cardas told me that they cannot use Neutral Ref. IC because it has not enough conductors, BUT, they can make one with Neutral Ref. Video and it may take 60 to 90 days.
So i ordered a custom N.R. HD-650 headphone cable (3 meter) via the french distributor and patiently waited...2 months.
It finally arrived on tuesday 30 March and after only one week of use i think i can tell that it's a really fantastic cable.
The construction: Well if you ever saw a piece of N.R. video cable it's made with the same cable. A pretty stiff one not easy to move around with. For me it's not a problem as i don't move that much when i listen to music. But fact is that you cannot move like with other cable.
Overall construction meet the usual Cardas standart build...very good. One thing that surprise me is that the 2 leads that goes to the earcups are very small ( 2x thinner than the 'smurf').
Brian already told me that the standart HD-6X0 cable use larger conductors, but the N.R. has a much more complex geometry and better shielding.
The sound: Clean, clean, clean. The amount of details this cable bring is just amazing. Like removing another curtain. I'm closer than ever to the original recording event.
You can clearly hear all the small harmonics like from a hi-hat buried into the mix, cymbals are fantastic, they shine like the real ones. You can hear piano or guitars string in ALL their glory. Bass and drums are tight and fast...incredible. More transparency, everything is clean and sound like the real thing!. Faster, cleaner, and 'punchier' sound. The soundstage depth and width has no increased, but placement of the different instruments or sounds is more precise. The difference in sound 'ambience' from one recording to one other is now crystal-clear. This cable is a winner.
( This in comparison with the 'standart' Cardas first generation HD-600 cable).
System used: Studer D731 cdp---> Golden Ref.IC--->Manley 300B pre/headamp--->N.R. headphone cable---> Senn. HD-650.
Conclusion: Who needs this cable? If you have invested maybe $7-8k and more in an HD-650 setup (or if you wanna see/hear the guts of your BlockHead) and if you think you can squeeze the last bit of 'musicality' from your setup, then go for it. Ask your local Cardas dealer for a price quotation. I paid €575 for it!, more than the phones itself...call me madman i like that!. You lucky Americans can have it for something like $300-400 i guess.
Thanks for the interest.
