Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Aug 26, 2020 at 1:07 AM Post #978 of 1,466
Shanling, when you will fix 44.1khz by usb on linux devices? This is the same problem as with Linux on PC which I have reported some month ago (First report).
I have tried to use shanling up2 with my android device by usb (using UAPP) and there is no sound when I'm tried to play 44.1/16 files. If I play 48/16 file all working good. To reproduce this problem use UAPP or Hiby music in direct usb mode (without android mixer). Or download any linux distributive on PC and try to play 44.1 files without resample. And fix is please!
Hi, is this any workaround for this issue?
I'm using OnePlus 7 pro with USB Audio Player Pro and direct play via USB DAC.
No problem playing 48khz files, but when I play 44.1khz files, there are no sound.
Already updated to filmware 1.7.5 still facing this issue.
Thanks.
Aug 26, 2020 at 1:49 AM Post #979 of 1,466
@Shanling would you care to address my issue? Thank you, in advance.
Thanks.
No update on that.
Aug 26, 2020 at 4:24 AM Post #980 of 1,466
Shanling Controller app for UP2 & UP4 is now available for iOS devices!
Search for "Shanling controller" in App store
https://apps.apple.com/us/app/shanling-controller/id1505751654?l=en
We also released updated app for Android, update is now available in Play Store
Make sure UP2 & UP4 have latest firmware installed
http://en.shanling.com/article-CompanionApp.html
Just got UP2 and I'm unable to get the device recognised in the iOS app. However I'm able to get the device connected in the bluetooth menu.
Aug 26, 2020 at 4:26 AM Post #981 of 1,466
Please try to update to latest firmware over computer, it's possible your UP2 has older firmware that's not compatible with the app.
Aug 29, 2020 at 2:00 PM Post #982 of 1,466
New firmware update for Shanling UP4, V1.1.
Download from our website or from Google Drive
Changes and fixes:
1. Low battery warning is disabled while music is playing.
2. Fixed problem causing volume jump after connection.
3. Fixed problem causing channel imbalance.
4. Fixed problem of missing first second when using WeChat.
5. Other bug fixes.
There is still little bit channel imbalance with my unit on firmware 1.3
Sep 2, 2020 at 6:20 AM Post #983 of 1,466
Hello, I am trying to update to last firmware of UP2 on Windows. When I click "Start upgrade", there is "Bluetooth DFU" alert: "No DFU firmware in the current folder". The devise is in DFU mode, according to manual instructions. In "Firmware upgrade" folder there is DFU item. So, what is wrong?
Sep 2, 2020 at 9:34 PM Post #984 of 1,466
Is your UP2 showing in device manager properly as DFU device?
Sep 3, 2020 at 2:35 PM Post #986 of 1,466
When I click on an application, it starts installing drivers. It says there:
"First: DFU USB Driver Installed
Second: Microsoft Visual C++ 2008 Redistributable not installed."
It seems, progress goes only to the half and then next window appear with „Start update” button.
Maybe issue is in this second task?
Sep 3, 2020 at 9:23 PM Post #987 of 1,466
You mean item „CSR Blue Core in DFU mode”? Yes, it has appeared.
Didn't face such issue before. I would recommend to do fresh download of the update file, just to make sure you got all the files in correct place and without any error while unzipping it.
This is fine, no issue there.
Sep 4, 2020 at 4:07 AM Post #988 of 1,466
I did the fresh download of the update file, but no effect.
I tryed on 2 computers with different Windows version. On one of the computer, in the past, I successfully upgraded UP2 to version 1.5 and there was no problem.
Can I download from somewhere version 1.6? Mayby from this version I could try to update version 1.7.5.
I would like to have acces to Shanling app, but from version 1.5 there is no possibility.
Sep 4, 2020 at 4:13 AM Post #989 of 1,466
There is no version V1.6.
Here you can download V1.7.3, which is using same update method as V1.7.5 https://drive.google.com/file/d/1ygXJezKrQm7sgB1zN9ZJnwTOwVDtCIbr/view?usp=sharing
Sep 4, 2020 at 4:19 AM Post #990 of 1,466
Just a suggestion: move the entire 'Firmware Upgrade" folder (and only that folder) out to the desktop, then re-run the process.
