Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Sep 2, 2019 at 2:16 AM Post #317 of 1,466
Hi @Shanling @all
Having my UP2 since today, I'm facing one issue, when i turn the knob to change volume, either both directions will lift the volume, or it doesn't work at all till I reboot the device.
Is somebody else facing this issue?
except this, awesome Device! best BT Audio receiver I used so far (coming from a Bluewave GET).
Glued it to the side of my Oppo PM3 and created a super short cable, working just perfect overall :)
Thanks!
Did you update firmware to latest V1.4?
Hi @Shanling , hi all
I am about to purchase the up2, and one of the purpose will be to watch TV at night while the family sleeps, using headphones from 32 to 80ohms. I want to make sure it will be detected by my Sony TV, wich only connect with A2DP Bluetooth profiles. Will the UP2 be detected by my TV?
I can't find the information anywhere, thank you in advance.
UP2 shows to other devices as Bluetooth headphones, so if your TV can work with standard BT headphones, it should work with UP2 also.
Shanling is on fiyah!
Will these double DACs work as dual mono for 3.5 output? Can you tell us the size of the device?
For that we have the Dual DAC mode. Both DACs active in Single-ended and with more power.
@Shanling Could we at least have a rough estimated price please? Would be nice to know cause I myself and many others here (I'm sure) have been considering the Fiio BTR5.
Will get it to you as soon as somebody tells me.
Sep 2, 2019 at 3:15 AM Post #319 of 1,466
Sep 2, 2019 at 8:49 PM Post #321 of 1,466
Sep 3, 2019 at 11:59 AM Post #323 of 1,466
How do the UP4s abilities stack up against the M0? I'd likely be using it as a USB DAC.
Sep 3, 2019 at 12:27 PM Post #324 of 1,466
I've got the M5s and UP2. I've also got a BTR3. As a USB DAC, the UP2 creams the the BTR3, it's cleaner and less congested. So I am certain the The UP4 with dual DACs will surpass the UP2 and although my UP2 is only a month old I'll be getting the 4!
Sep 3, 2019 at 7:45 PM Post #325 of 1,466
I wonder if UP4 balance would be better than UP2 with Ibasso DC01 balance, assuming this is supported by the usb dac.
I suppose you can try two different balance if UP4 supported usb dac function with Ibasso DC01.
Furthermore if UP2 can work with usb dac via otg and a hub for power then E1DA which is power hungry, then UP2 too can run different balance option.
Sep 3, 2019 at 9:19 PM Post #326 of 1,466
UP4 is dedicated Bluetooth amplifier, so more codec supply, better quality of signal and of course balanced with dual DAC compared to M0.
But USB input on UP4 is limited to 16/48, so if you want to play Hi-Res, you need to go with M0.
UP2 is not digital transport, so it can't be used with iBasso.
Sep 4, 2019 at 2:23 AM Post #330 of 1,466
Do you support shanling up4 usb dac 32/384?
No, limited to 16/48.
hi Shanling,
Finally i got the SU2 and it's great product.
My concern is how to connect the SU2 with laptop through cable C? juts plug-in cable to laptop and SU2 ?
I already update latest firmware v1.4 for SU2
Connect it to computer with USB-C cable and then turn on UP2. LED should change colour from red to purple.
