Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Aug 24, 2019 at 5:57 AM Post #301 of 1,466
That's just a silly myth people keep circulate around. No even Shanling, or any manufacturer, will dare to say their first release of product will be completely bug-free in firmware, otherwise there won't be a need to update UP2's firmware at all. If that logic makes any sense, isn't every manufacturers that ever release a bug-fixing firmware be labeled as beta testing their customers?
The reason I dumped my BTR3 in favour of UP2 is because a firmware update actually broke functionality for my BTR3/Phone. So even when they try and improve things with an update they can sometimes get worse. (This applies to all manufacturers).
Aug 24, 2019 at 7:54 AM Post #302 of 1,466
The truth is I don't know, but I see a lot of people with complaints about the fiio and for that reason I discard it, I also liked the design of the up2
Aug 24, 2019 at 5:05 PM Post #303 of 1,466
Yeah, I've got a bit of a love/hate relationship with FiiO; they have great products but with some major annoyances (often software related).
I haven't had any experience with Shanling yet. Maybe this would be a good product of theirs to try.
Aug 25, 2019 at 8:50 PM Post #304 of 1,466
How can I find out what firmware I have on my device. Sound great but having a little trouble turning on device. I have to plug the up2 to my charger and then it turns on. Battery is also fully charged.
At current time, there is no way how to figure out which firmware is your unit.
We recommend new owners to simple update to latest firmware available on our web.
And can you tell me in PM little bit more about problem you are facing?
Aug 25, 2019 at 11:14 PM Post #305 of 1,466
There is no problem. I was using my usb c to usb c cable to charge and it didn’t take. I used the supplied cable and it charges with no problem.
Aug 26, 2019 at 1:33 AM Post #306 of 1,466
I see, you are not first one mentioning problems with USB-C - USC-C charging cable. Can you please tell me which charger you were using?
Aug 30, 2019 at 10:21 AM Post #308 of 1,466
Hi @Shanling @all
Having my UP2 since today, I'm facing one issue, when i turn the knob to change volume, either both directions will lift the volume, or it doesn't work at all till I reboot the device.
Is somebody else facing this issue?
except this, awesome Device! best BT Audio receiver I used so far (coming from a Bluewave GET).
Glued it to the side of my Oppo PM3 and created a super short cable, working just perfect overall :)
Thanks!
Aug 31, 2019 at 4:27 AM Post #309 of 1,466
Hi @Shanling , hi all
I am about to purchase the up2, and one of the purpose will be to watch TV at night while the family sleeps, using headphones from 32 to 80ohms. I want to make sure it will be detected by my Sony TV, wich only connect with A2DP Bluetooth profiles. Will the UP2 be detected by my TV?
I can't find the information anywhere, thank you in advance.
Sep 1, 2019 at 3:44 PM Post #310 of 1,466
All Bluetooth devices support A2DP: https://www.howtogeek.com/338750/whats-the-difference-between-bluetooth-a2dp-and-aptx/
However, you will get a much better audio with a transmitter like the one I use: https://www.aliexpress.com/item/32844963478.html
Not only it supports APTX, but it supports APTX Low Latency (as does UP2) - perfect for TV viewing.
Sep 1, 2019 at 4:39 PM Post #311 of 1,466
Sep 1, 2019 at 11:59 PM Post #312 of 1,466
Introducing Shanling UP4, extra powerful balanced Bluetooth Amplifier.
Key specification:
Dual ES9218P DAC/AMP
- 3.5mm Single-ended and 2.5mm balanced output
- High gain / Low gain / Dual DAC mode
- 91 mW@32Ohm Single-Ended and 160 mW@32Ohm Balanced output
- NFC pairing
- Bluetooth 5.0 Qualcomm CSR8675 chip
- Supports LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX, AAC and SBC codecs
- Thin and sleek design for your pocket, comes with additional case with clip
- Multifunctional wheel for total control over playback and calls
- Build-in microphone for phone calls and voice assistants
- Can be connected to computer to serve as USB DAC
- Battery life up to 15 (SE) / 10 (H) hours
Available during fall 2019
Sep 2, 2019 at 12:11 AM Post #313 of 1,466
A proper ES100 / BTR5 competition I see.
Sep 2, 2019 at 12:46 AM Post #315 of 1,466
I really need an app for UP2 and upcoming UP4!
